02-03 Lancer Show / Shine Post your pictures, photoshops, and videos!
Need help with side reflector removal
Old Jul 1, 2014, 12:49 AM
jimbo74's Avatar
I need help with the side reflector removal. It is currently, the yellow reflector in my front bumper of a 2003 Lancer ES. I have purchased clears for it, as I don't like the look of the yellow.
I do have the FSM but did not see what I have to remove. Should I remove the wheel and take out the inner wheelwell?
It is this, right here:
Old Jul 1, 2014, 03:45 PM
jimbo74's Avatar
well, got it done, there are about 5 little plug clips per side, underneath that come off, the left side was easy, the right side was a little bit harder.... the right side, has the windshield washer reservoir, realizing it was riveted into a support, meant I couldn't remove it. I did take out 2 bolts though, which allowed me enough room to move it around after I also removed the right headlight housing. I was then able to move the reservoir enough to use a right angle, ratcheting screwdriver and got it all back together.....
evoDON
Mar 3, 2015 09:21 AM
RussellDaniel
Mar 5, 2014 07:17 AM
Lancer17
Apr 19, 2011 07:34 PM
bluegsr
Nov 16, 2009 07:04 AM
Quick Reply: Need help with side reflector removal
