how to install e-brake bypass for alpine
i think u need the buy the litle box that fools it. If i remember correctly the alpines want to see 12 volts from the brake switch then grd from the ebrake. After that 12v needs to be taken away and a grd signal still applied. Look on ebay for one
With Alpine this is what you do...
You have to press the foot brake, then engage the emergency brake, then let go of the foot brake...if you know what you are doing you will know how to bypass this using switches
Originally Posted by BoostWhore
Just like i said before Alpines need to see 12v from the brake switch then grd from the ebrake.
To watch TV, switch on toggle 1, then toggle 2, then turn off toggle 1 again. Done.
Import Junky
54
Apr 20, 2008 08:06 PM
Canadian Canuck
Apr 7, 2008 08:04 PM
vetboss
13
Jan 1, 2008 11:18 AM
