How to eliminate automatic Day Time Light
#31
Originally Posted by morpheus256
well, id rather not fry the one and only red box i have lol. if black rally could open his up and grab some more pictures that would be cool.
also, if you need any REALLY high res pictures i can take them at much higher resolutions.
i dont have a digital camera but, let me ask to my brother maybe he has one
#32
that would be cool, since i now have my green spec one, im happy
but there are lots of people on mitsunation (where im more commonly found) that would benifit from this information greatly,
along with all the 06 US lancers here.
i took the pictures for reference, and to try and help someone who is more electronicaly ept to figure it out
#34
hey black rally, which wire did you unhook
today my green ecu came in from ebay so i could disable them, so i decied to solve this once and for all, and took pictures of the inside of my red ecu.
http://morpheus256.is-a-geek.com/lan...u/CIMG0292.JPG
http://morpheus256.is-a-geek.com/lan...u/CIMG0294.JPG
http://morpheus256.is-a-geek.com/lan...u/CIMG0295.JPG
this may help ALL the canadian RA owners (except for me since i now have a green ecu and could care less :P)
In this pic:
Put out the white cable from the plug, red and blue leave them conected to the ECU.
You will solder the white cable to the pin 5 from left to right on this pic:
Now you will not have the daylight and can install HID lights well....
#35
ok, i decied to do some more research, heres some better pictures on the fet assembly
http://morpheus256.is-a-geek.com/lan...u/CIMG0362.JPG
http://morpheus256.is-a-geek.com/lan...u/CIMG0363.JPG
heres the datasheet on the fet
http://www.ortodoxism.ro/datasheets/...n/1-bts555.pdf
pins 1 and 5 on the fet are tied togeather for "high current applications" which is connected to the blue wire (output) the red wire is connected to pin 3 which is Vbb+ i Belive white goes to pin 2 which is IN...... im gonna keep working on this a little bit
what does pin 5 on the etacs modual do exactly?
EDIT: between a friend and i, we found that pin "5" is actually pin 25 on A-11X which is the low beams switch on the steering colume, which will turn on the fet at 100%
if anyone REALLY cares about all the technical crap
thanks for a kick in the right direction VIJOVAME
#40
This is the box wide open.
Ralliart 2006 here in Puerto Rico.
I bend the pin that deliver the DRL signal.
So no DRL right now.
Now I have a Question.
I bought the Morimoto D2S 4.0
When It is supposed to be in
high beam, projector's solenoid is
on low beam position. The problem with this
Is that panel indicates the opposed of reality
and fog light only turn on with High beam.
I tried changing polarity on solenoid it didn't change.
Any help with that ?
Gtimportfanatic
Sep 15, 2017 09:06 AM
shane_evo7
Oct 8, 2016 07:02 PM
tiesto14
14
May 19, 2016 08:52 PM
