ralliart stock fog light wiring diagram
Old Aug 20, 2006, 10:07 PM
marshall15's Avatar
hey guys i got an 05 ES. so it means i dont have a stock fog lights. i found out that there is a factory wire harness to hook up a set of fogs. will someone help me with the fog light wiring so i can get a clean look. i got a fog light off ebay which i want to hook up with the factory wire harness instead of running another wiring setup. thanks
Old Aug 20, 2006, 11:09 PM
DangerousDan's Avatar
maybe this will help
Attached Thumbnails ralliart stock fog light wiring diagram-m2285404_00330.png   ralliart stock fog light wiring diagram-m2285404_00331.png   ralliart stock fog light wiring diagram-m2285404_00332.png   ralliart stock fog light wiring diagram-m2285404_00333.png
Old Aug 20, 2006, 11:26 PM
Myszkewicz's Avatar
Look for that connector A30 just behind the front bumper, down at the bottom center of the front end. Besides that, you'll probably need to add the relay A-04X, and get the wiring harness from a dealer (if it doesn't come with it on Ebay).
The wiring is part# MN124940, available for $21 from mitsubishiparts.com
Old Aug 21, 2006, 07:18 PM
marshall15's Avatar
does the stock fogs lit up when you have the headlights open? since when i connect the wiring off ebay i have the option when to get the fogs open. just read some post that it does turns off when you have the headlights open. just asking for options/.
Old Aug 21, 2006, 09:58 PM
Myszkewicz's Avatar
Er, I think you're asking when the stock wiring will allow you to have the fog lights on? Only with the low beams on. If you turn on the high beams, the fogs turn off. If you turn the headlights off, the fogs turn off.
You can get around all that, though. There's a thread about it in the how-to tips/requests section.
myersOS16
Outlander Sport
14
Jul 26, 2019 03:41 PM
Pipefish
Outlander Sport
27
Mar 31, 2018 02:36 PM
EvokidIX
Mar 12, 2016 04:08 PM
marshall15
Aug 21, 2006 07:19 PM
Quick Reply: ralliart stock fog light wiring diagram
