Cruise Control Lever Relocation for Evo Wheel
Old Aug 31, 2007, 02:40 PM
Diavlo's Avatar
So, you want the Evo wheel, but also want cruise control. Many put off getting this vastly superior wheel simply because they dont want to lose their cruise.
Well, now you dont have to!
So heres the basic idea:
1). Remove your cruise lever from your stock steering wheel, or order a new one (they are suprisingly cheap!).
2). Find a place to locate the lever. I found the hole in the cupholder segment of the center console to be perfect.
3). Make a bracket to hold it. This is the most difficult bit, but its just a case of getting it aligned.
4). The wiring. The lever has two wires that need connecting, and it doesnt seem to matter which way around you wire them.
The wires come from the ECU to the blue 11-pin plug C-108:
C-108 plug is located down behind the corner trim at the bottom of the footwell next to the door opening.
Once youve located C-108 (the cruise control plug), you need to know what each wire does:
11 - Blue - Stop Pedal Canceller
8 - Orange - Cruise Indicator Light
2 - White - Cruise Lever Wire 1
3 - Light Green - Cruise Lever Wire 2
9 - Gray - Clutch Pedal Canceller
What you need to do is cut the white and light green wires in pin 2 and 3, and extend them to your new lever location. Make sure your taking the wires from the ECM and not from the other side of the plug which takes those wires to the steering column clock spring, and thus the old location of the cruise lever!
Here is a diagram of the cruise lever circuit...
Thats it, simple as.
Old Aug 31, 2007, 04:41 PM
MITVRX's Avatar
lol, crazy.
You should put a "NOS" symbol on there! haha.
Old Aug 31, 2007, 09:13 PM
flybyjs130's Avatar
so im assuming you pulled out the original 2 wires from the stock steering wheel, extended the wires to reach the center console, created the bracket n set the alignment. correct me if im wrong
Old Sep 1, 2007, 11:17 PM
bruce988jl's Avatar
Well it looks as though he just ran new wires to tap into the stock location wires. He didn't even mention relocating the wires, most likely tapping into them right where they are near the ECM and leaving the stock wires which would wind up being cut or just there.
Old Sep 2, 2007, 12:16 PM
Diavlo's Avatar
I just ran new wires.
Old Oct 2, 2007, 09:13 PM
NewEvolutionIX's Avatar
Does anyone know where I can buy a Cruise Control for my Evo?
Old Oct 2, 2007, 09:19 PM
krazy srt4's Avatar
rostra sells one i bought it but never got to installing it
Old Oct 3, 2007, 05:57 PM
Do you know where I can get one cheaper than 230?
Old Oct 5, 2007, 10:00 AM
sgand's Avatar
I'd like to know where to get just a switch for it. I can't even find any while searching google.
Old Oct 7, 2007, 09:13 AM
JohnnyBoy427's Avatar
did you try ebay?
Old Oct 16, 2007, 11:50 PM
kyled63901's Avatar
you need to try discountmitsubishiparts.com they have almost any part you could want. all you do is enter the year and model in the box and it pulls up different sections of the car and you just keep drilling down til you find what you want. pm me if you did find this site helpful to you
Old Oct 18, 2007, 09:08 AM
sgand's Avatar
Why are you curious if it helped me?
Old Jun 29, 2008, 08:22 PM
Ralli04Art's Avatar
When i had my ralliart. i just put the cruise control sticker in the evo wheel.....DUH.
Theres a freakin spot for it for gods sake.
Old Apr 7, 2009, 10:08 PM
samterry1234's Avatar
what about an evo X steering wheel, is it still a direct replacement?
Old Apr 8, 2009, 11:15 AM
cubenoob's Avatar
^ I don't believe the Evo X steering wheel will fit our cars.
Quick Reply: Cruise Control Lever Relocation for Evo Wheel
