2004 mitsubishi lancer ralliart 2.4l sohc
I need help with my lancer ralliart. I replaced the cam sensor plugs wires alternator starter cleaned injectors replaced mfi relay and can only run on starter fluid. Checked to see if injectors were spitting and they do andw it's getting fuel. I can't figure out why it won't start help me PLEASE!!!!
so it will only run with starter fluid, but you're getting fuel? I'm assuming if it runs on starter spray, you must be getting spark, unless it's just dieseling on the starter spray. any other symptoms? might not be a bad idea to verify you have spark.
also did you change all those parts to try and fix the problem, or did the problem arise after changing these parts?
Well we got the car running. There was really dirty gas in the fuel pump and lines it was almost like mud lol. But now we have a bigger problem. The car blew a huge hole in the front end of the block. Now I need a new bare block. Any suggestions for a super cheap block?
No we got it started and drove around for a few hours and pulled out of the parking lot and gave it some gas and it just blew up in the middle of the road lol. Now we need a new block for a 2.4l mi-vec sohc lol this **** sucks
broke06RS
Nov 19, 2015 08:16 AM
danmark
10
Dec 31, 2012 10:17 AM
LT1runner
10
Oct 20, 2008 05:59 AM
