04 Ralliart indicator/headlight problem
Old Sep 5, 2015, 11:02 PM
MitsuAUS's Avatar
Hi all,
Got an annoying issue with my lancer that has me a bit stumped.
I turned on the ACC power this morning and the right hand indicator blinked by itself for several seconds and then stopped. Now I can't turn on either indicator or high/low beam. Hazards still fuction normally. Opened up the sterrong column and lever housing and nothing seems to be damaged or out of place.
I'm going to visit a wreckers in the morning to grab a replacement lever. Failing that, would replacing the front ECU be the next step?
Would appreciate any insight
Old Sep 6, 2015, 08:07 AM
Raikiri's Avatar
Clock spring?
Old Sep 6, 2015, 06:56 PM
MitsuAUS's Avatar
Ended up replacing the combination. Seems to have solved the problem
MitsuAUS
Sep 6, 2015 12:34 PM
quadrophine
21
Apr 17, 2013 09:21 AM
MJ23FE
MitsubishiParts.net - WA
Nov 16, 2010 09:44 AM
MJ23FE
Nov 15, 2010 11:51 PM
alex_alex
Jul 31, 2003 05:38 PM
Quick Reply: 04 Ralliart indicator/headlight problem
