DirtyRalli's RA
Ill see if i can take some pics tmw...pretty sure anywhere behimd the wheel on the plastic should be ok..... And as for the mudflaps on a wingless car i think it would look badass..... Iv wanted to go wingless for a while now but im still attahced to my evo wing loll
UPDATE: she is currently in the shop right now getting lots of work done
Act stage1 clutch
Clutchmaster flywheel
Megan racing rad
Mishimoto fans
Rpw stage 2 camshaft and cam gear
Red valve cover
Slotted/drilled rotors and ceramic pads
Then it will be going off to the tuner to get the hackish reflash and a fine tune on the dyno..... Im hoping to see 200whp
Act stage1 clutch
Megan racing rad
Mishimoto fans
Red valve cover
My car is pretty much done for this summer...so far i did megan rad, mishimoto fans, cm lightweight flywheel, act stage 1 clutch, rpw stage 2 cam and cam gear, aem wideband, hackish reflash and hopefully this wednesday the car is goimg on the dyno to get the most power and help it run better
The emgine bay now
The emgine bay now
