04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Car bogging on wot
Old Oct 21, 2008, 08:13 AM
chu
chu's Avatar
Originally Posted by 80210
I'm having the same problem, slow boost to about 10PSI then spikes to 22, stutters, and backfires/small explosion feeling
Could this be cause of spark plugs?
Only way to find out is to remove the plugs and check, but it seems to always be the problem. BTW, seems like you're running turbo, are you running a step colder?
Old Oct 25, 2008, 05:54 PM
GearDownSon's Avatar
Check ur plugs first. Did you swap em out when u went turbo? Is it rrms?
Do you have a wideband running? What readings you getting?
Is it throwing the car in limp mode?
I had a similar prob with mine an it was a small hole in a coupler.
Triple check all your IC pipes.
Need mor info
Old Oct 25, 2008, 05:56 PM
lancer2show's Avatar
i had a lot of bogging at first. when i changed my spark plugs it worked fine.
Old Nov 30, 2016, 09:07 PM
Jdizzo33's Avatar
Need help my Evo Mr just start bogging like 3 days ago normal driving fine if I step on it to boost it boggs backfire help I changed plugs checked all intercooler piping tight need help like asap
Old Dec 2, 2016, 05:42 AM
CrAnSwIcK's Avatar
wrong section, but do you have a wideband? knowing what the AFR is at when it's bogging would be helpful.
Old Dec 5, 2016, 01:46 PM
Jdizzo33's Avatar
Mines was doing the same thing I have a 2010 full exhaust Cobb stage 2 acessport Evo turbo intercooler injectors it was the fuel relay change both recommend the blue relays they work better car is back to normal now
Jdizzo33's Avatar
Change the fuel relays both them
4G63_Crazy
Sep 14, 2017 07:50 AM
4G63_EVO
Jul 15, 2017 12:03 PM
Mackman
Apr 19, 2017 08:04 PM
Mrjafrancis
Dec 23, 2016 05:01 AM
Jdizzo33
Dec 2, 2016 12:23 AM
Quick Reply: Car bogging on wot
