DIY Log manifold
Rebuilding the 14b is only half of the battle, its quicker spooling, 6cm^2 exhaust housing is likely to be cracked (16g's use larger, 7cm^2 exhaust housings).
So if you ever want to speed-up 16g's responce, you can always try 14b turbine housing (assuming that you can find a nice one).
As promised, here is the progress i made this morning with the custom 4G69 turbo manifold," Log" style, in other words, the easiest and cheapest to fabricate:
You've all seen the pieces i had, a 4G69 exhaust flange, 2 butt-weld tees, and 2 mandrel bent 90 degree elbows, all around 3/16" thick, the flange is 3/8".
Cutting: made easy, originally i was going to do it mby hand with a angle grinder and a zip cutter.
Had to take quite a bit off.
All fitted, ready for media (sand) blasting, yay!
All chamferred and and sand blasted, prepping is done!
Time for welding, what we did first was tacked it to the flange and welded the top, or front of the log, then cut it off the flange to weld the "belly"...once the LOG was done, we welded it to the flange, very tight spaces...
ALL DONE!
ALL DONE!
Sorry, I didn't see your reply before.
No, I wouldn't worry about it, 14b was originally meant to push 9-10.5 psi on 1Gs. We have pushed them over 25 psi, but they are not happy there .
Manifold is looking great!
good job of welding looking good. As I said when I saw the pieces for the first time glad to see you are using the right material do deal with the heat and power.
As far as the angle goes remember to give yourself a bit more room for turbo upgrdes dow the road, that manifold will last a long time.
I just helped with cutting cause i knew what i wanted, and i did the media blasting. My mom's boyfriend is the welder, he's qualified on many metals, i.e. cobalt, titanium. etc. I wish i could weld like that. I can mig, but it don't look that good.
No problem, Nick...Just doing my best to contribute, and pass on the information i gather. This is the most cost effective solution i could come up with for a turbo manifold, mind you if you had to pay someone to weld it, it would not be so cost effective. But it's an option at least.
When you coming down to play with my suspension? You still got "teens" on the mind? LOL! that'll never get old, thanks Rob.
Early monday morning update, since the wife woke me up, and i'm on evening shift this week, lol...
Ok, so here's how the manifold is coming along...it sucks cause i can only get into the shop like once, maybe twice a month, but it's good cause it's not costing me anything. This weekend, we used some rough measurements to mount the flange on the turbo, fitment details will be posted in my build thread. This thread is all about the manifold.
First thing we did was cope a piece of pipe...
Next, we cut the flange, because of space restriction, so that i can start the 2 bolts in the side closest to the engine and just slide it in place, as there is no room to drop bolts down through, or get nuts on the end of a stud.
Here's the pipe, compound cut at 41 degrees, and 8 degrees
We cut the hole.
and then we just tacked the pipe and flange on for fitting, and once we have it perfect then it'll get welded up.
We cut the hole.
Went in for final welding on the manifold this morning...went pretty smooth, made a few adjustments, i'll explain each picture briefly.
BEHOLD!
We cut some bolt head relief into the pipe, the pipe wall is quite thick, so unnecessary material was removed to allow more space for the turbo bolts.
Flange welded...
Little bit of porting, just to remove excess material in the exhaust port.
*DRUM ROLL*
After some sand blasting, and a light coat of oil...
TAH-DAH!!
Thanks for watching, if you have any questions, send me a PM.
Total cost 105$ in material.
Welding and fabricating, done by myself and a friend.
Hope this helps anyone trying to go forced induction on a budget.
cheers!
-Garrett
BEHOLD!
Flange welded...
*DRUM ROLL*
TAH-DAH!!
cheers!
-Garrett
