Stiff Shifting?
Stiff Shifting?
Well i drove to school today, and the shifting process felt fine, but afterschool when i was driving home and the car was warmed up and everything the shifter felt really sloppy. Like normally i can have it in neutral and play around with it (wiggle it left and right) to make sure it's in neutral, but now when it's in neutral it don't do it, instead it feels really stiff and encounters what seems to be the seperator to the gears for the shifter to follow while shifting. Another thing, when i shift into 3rd, from neutral or from 2nd/4th it feels really sloppy, and it's no longer a mechanical feeling instead it feels like ****...
Any ideas guys? Anyone else have this problem? I haven't done anything to the drivetrain/clutch system to the car, nor have i been pushing it lately...
This was really weird and it's only happened once (yesterday) so far, I got locked INTO 5th! I was taking the off ramp on my way to work and I had to put the clutch in 3-4 times really quick to get it out of 5th. It freaked my **** real good when it happened. It's the one thing I never expected to happen with a DSM, getting locked into a gear not out of one. Anyone else?
I've had 3 DSMs, and about 8 transmissions.
haha, you're almost as bad as this kid i know.. he went through a tranny in a scion (which are supposedly supposed to have good trannies) in a matter of i believe 2-3 months.. that's also 1 of the many trannies he's blown. Not sure how many but he's up there with you
Originally Posted by bruce988jl
haha i'd just toss it in reverse...
Originally Posted by Myszkewicz
Not when the last stop sign was still 10 miles from home. When the other gears went, I was over 100 miles away. I babied it up onto the interstate (figuring I'd have to use my AAA-plus to tow me home), found out 5th gear was fine, and just didn't take it out of 5th until it was time to back it into my driveway.
Definitely change your fluid. There may be something in there that's draining down when the car sits, but gets circulated up to the gears as you drive, and causes your problems. $10 to try to fix it yourself isn't too bad.
If that doesn't do it, get the car nice and warm, and take it back to the dealer.
alright i'm gonna try that... I think my clutch is fine, shouldn't be that if that has anything to do with it.. but i'll replace the fliud, any suggestions on what to replace it with (without mitsubishi going awol on my *** for putting in the wrong fluid).
The manual specifies API class GL-4, in 75w-85 or 75w-90 weight. I will say that the stuff I drained out of mine felt and flowed like it was a lot thinner than that. It didn't smell like gear oil, either. You could call a Mitsu dealer (not necessarily the one you'd be taking your car to), and ask what you should put in there.
