Which one is the Fuel Pump Relay?
Hey guys! Since the other day out of nowhere my car hasn't started or started with a little help from starting fluid and then died. Then we were able to start the car by directly powering the fuel pump, so now I know that fuel pump is fine, but I wanted to check the fuel pump relay, but I have no idea which one of the relays it is. Any help will be greatly apreciated! I tried looking at past threads but could only find relay info on the Evo and newer Ralliart (Mine is 2005).
there's two, they are both on the fuse panel under the steering wheel to the left. they are on the left side of the panel. I'll get a pic for ya
*edit
Ok, so here's where they are, terminals 2-3 i'm pretty sure is the coil, 1-4 is the switching part, be sure to check both, and don't forget continuity between 1-4 can only be verified with the coil energized, not sure how much . Also, always disconnect the battery whenever you work on any circuitry.
Shyt! those arrows should be up about an inch or so, those empty sockets are nothing, lol (I obviously don't know how to use OpenOffice Drawing)... but those two relays on the left side with the green marks and the writing on them is what you're looking for.
*edit
Lightsaber
Apr 4, 2018 10:02 AM
Carloverx
14
Dec 22, 2011 01:00 PM
