F4A4B Transmission Overhaul
Hey guys, im rebuilding my automatic in my 05 RA, I been going at it for a month now. and to no prevail I just cant seem to find the right clutches and steels that will fit this transmission of ours. the transmission looks identical to the f4a41, f4a42, and f4a51. the difference is the internals. I tried using the f4a51 clutches and steals and they don't work at all, they don't match the original clutches and steals at all. so im hoping the f4a41 or 42 transmission's clutches and steals will work. I consider this a learning experience for those who are planning on rebuilding their automatic can benefit from what I am learning about our transmission. so far what I have learned is the f4a51 and f4a42 seals will work with our auto's. the lock nut on the output shaft is hard to find and class mate of mine that owns 3 3000gt vr4's got my nut from 3sx.com with no problem and a new cap for the output shaft. so far that's all I got done and would like some help trying to figure out what will and wont work with this transmission.
again for reference; seal kit from the f4a41, f4a42, and f4a51 will fit our automatic transmission.
any comments and ideas or input from someone who has already done this is welcome and if you can give me part numbers.
it's Mitsubishi ASA...has the parts breakdown and part numbers for every single part of every Mitsubishi vehicle ever sold by MMNA (Mitsubishi motors north America). all models, all years, all trims (even broken down by USA (even different specs for California), Canadian, and Puerto rico and guam markets. It's current to the newest gen lancer and evo, and 4g eclipse, so at least up to 08. it's cool though cause it even has like 90's eclipse, mirage and Evo.
on that website, there's also CAPS, which is the same thing, but a little older...there are even versions of CAPS that have complete JDM catalogues.
it's an exe installer, installation instructions are built into the installer package.
Ok everyone its done. the tranny is finished and its ready to go back into the car. after all my research, I have finally came to the conclusion that the f4a4b automatic transmission in our cars is the same as the f4a41 and f4a42 in the lancer es and gallants. the only difference between ours and those transmissions is the differential and transfer drive gear. everything else is the same. so if your rebuilding your automatic, the f4a41/f4a42 frictions and steels kit will work. and the seals for the f4a51, f4a41, and f4a42 will fit as well. i forgot to give the part numbers to ssp for our frictions and steels. i am hoping they will be willing to make performance frictions and steels for our transmission since they do it for sst ralliarts and evo's. whats the worst they can say is no? also if the mods here can sticky this it would benefit others reading this. i done all the leg work for everyone with crans's help as well. thanks crans for the link you gave it helped out a lot.
