Ralliart 2006, No crank intermittent
Hi there! I have a Mitsubishi Lancer Ralliart 2006 manual transmission, 4g69 stock, A/C and remote start.
First of all, I tried to find solution in old threads but they were all left unsolved or not enough similar problem to mine.
I was getting random intermittent no crank issue for last 6 months, now it does happens way more often.
P0335 - Crankshaft Position Sensor A Circuit Malfunction
Read more at: http://www.obd-codes.com/p0335
Copyright © OBD-Codes.com
I get the P0335 Crankshaft Position sensor code.
While turning key, you can hear the relay and sound like a fuel pump.
I just replaced the starter.
I tried to unplug the CKP sensor, it would still do the problem (or just crank no start).
Here is what I found out; if you put the car in first gear, hold the clutch, move the car 1 feet and release the clutch; most of time I could crank and start again.
Anyone had this problem before or could help me with this?
Thanks! Much appreciated!
Michael
Michael
At first I thought the starter would get stuck in the flywheel and by doing this it would go back in place.
I read that if the CKP sensor would need replacement, you would get a crank no start or rought idle problem.
Mine wont crank like 30% of time but when I manage to crank, the car start and runs fine.
Thanks you!
Michael
Alright just for the update that may help others, I replaced the sensor and all timing belts components and the problem is gone. The balancer shaft belt was cracked all over and was kinda loose but still well timed.
The sensor was dirty but I bought a Beck Arnley one for 55$ CAN at Rockauto and replaced it. Sensing Blades on crankshaft are fine.
Thank you!
Thank you!
I did use the shop manual and torque everything to the right spec. The Gates timing belt kit did came with some instructions and torque specs.
This one is from my Ralliart 2006, replaced in 2016 with about 113000 KM.
I replaced the water pump, thermostat and the spark plugs as well.
I did not use locktite, but I think it's a great idea.
Thank you
Thank you
slicksta69
15
Jun 20, 2016 09:23 AM
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
