04-06 Ralliart Engine/Drivetrain (no forced induction)
Transmission Leak
Old Sep 2, 2015, 08:20 PM
lbwilliams44's Avatar
Transmission Leak
Discovered I have a pretty good transmission leak the other day, anybody know the part number that seals up that black plate?? Also there is a much smaller leak coming from that left area, Anybody have a layout or diagram?
Old Sep 2, 2015, 09:40 PM
CrAnSwIcK's Avatar
MD997740 aka grey RTV silicone sealant...lightly tighten, let set for a bit then torque...never had a leak on 3 rebuilds
has that case been opened or overhauled?
Evo7Life (Jul 2, 2018)
Old Sep 2, 2015, 09:50 PM
Negative, not yet at least. Those synchros are going to need some love at some point.
Old Sep 3, 2015, 10:10 AM
CrAnSwIcK's Avatar
seems odd that the inspection cover and case/clutch housing mating surface would just leak if it has never been taken apart. in any case, regular old permatex ultra grey is what i use.
Old Sep 3, 2015, 01:25 PM
Yeah, glad I noticed it. Picking up that sealant today, also got my RRM brake lines to swap out the old ones today. Once I am actually under the car I am going to make sure that's where it is coming from, but I am 99% sure it is. It's the only place there is any oil.
Old Sep 7, 2015, 08:10 PM
Yep, it was the inspection plate. Drove a little over 1k miles on it this weekend over some mountains, no leaks. As far as the other part, I smeared some over the crack lol. So far so good.
Old Sep 8, 2015, 04:24 AM
CrAnSwIcK's Avatar
hope it holds up for you...beats draining the oil, pulling it out, splitting it, and resealing...
Old Sep 9, 2015, 09:13 AM
Yeah that is what I am hoping for, buuuut it would be a good excuse to replace the clutch/flywheel
Old Sep 9, 2015, 10:22 AM
2006_RA's Avatar
^^ and differential.
Old Sep 10, 2015, 08:49 AM
That would be nice as well, depends if I can find a good package deal there
Old Apr 2, 2017, 10:09 AM
Royal Evo's Avatar
Hello Cranswick, I recently brought my 2004 Ralliart to a Mitsu dealer and have an engine oil and transmission oil change. Yes, I know I should have trusted my instinct and have done it myself. Anyway, that black plate is for inspection only, why would an oil leak there after a transmission oil change? What could the dealer have done to cause this. I bought this car with no oil leak under it and after bringing it over there, now i have an oil leak. Now, I will definitely not bring this car thre for timing belt and clutch replacement. What do you suggest that I should do to stop that leak? I mean, if i open it and re-seal that black plate, will it still leak inside and accumulate behind the black plate?
Old Apr 2, 2017, 10:39 AM
Royal Evo's Avatar
I think i found the cause, they didn't tighten the oil fill plug...its about a quarter to half turn loose...
Old Apr 7, 2017, 04:54 AM
CrAnSwIcK's Avatar
Oil sits on top of that plate, if you take it off, the transmission will drain its fluid...it's for inspection but also to remove/install the reverse idler gear during assembly and disassembly. There is no reason to remove this cover unless the intent is to disassemble the transmission.
Royal Evo (Apr 23, 2017)
Old Jul 2, 2018, 08:20 PM
Evo7Life's Avatar
Transmission Leak
So i just bought an Evo 7 and its leaking from the same spot is it an actual Gasket or is it Just a the MD997740 ??
Old Jul 3, 2018, 02:22 PM
You just use RTV sealant there, there is no factory gasket for that part.
Quick Reply: Transmission Leak
