Cranking but wont start, and no Spark please help
Bought a cam sensor, that wasn't it, I also checked the plug next to the motor going to the Crankshaft sensor and its getting power. So I am lost as to why it's still not working.
Well I pulled everything back off and looked again. I an getting power all the way to the sensor no problem at all. So any suggestions guys please. I don't want to take this car to the shop after all the work I've done.
It does still sound like something is wrong with some sensor that monitors timing. Be that cam or crank it sounds like one of them isnt signaling properly.
Come to think about it. Did you remove the crankshaft sprockets? You didnt happen to somehow get that sensing plate backwards did you? IIRC i think it has a different number of teeth on each side.
Do this. Or find another scanner at your local parts store. Get the exact fault code and we'll be able to better direct you from there.
Yes I am 110% positive that is it seated correctly. I am done throwing parts at it trust me, but most of what I replaced had never been done ever. So it's peace of mind to have newer parts on it.
your engine is out of time...I didn't even notice the picture of the first page, It must not have loaded on my ****ty internet, but your engine is waaaay out of time...you/someone used the crank pulley dowel as the timing mark. your valves are probably bent. You're about to put in a lot more money if you want that engine running. who installed that belt?
it also looks like your timing case is covered in oil or something...
fullm00nevo
13
Jun 10, 2015 12:07 PM
jabber316
Jul 20, 2014 03:32 PM
jabber316
European Forum
Jul 13, 2014 09:01 AM
