Stayer. Camshaft kit 4G69.
It is possible to buy. It costs 600$. Price includes: Work with the camshaft. Work the rockers mivec. Reflash ECU.
Attention. Without reflash it doesn't work.
After regrinding, the valve rises above, and is longer in the open state. Therefore, for the same period as before, the cylinders gets more air. If you do reflash, then the mixture will be very poor. It will detonate. You will not get an increase in power. You need to make adjustments to fuel maps and ignition.
That's about it. Thank you for your attention.
Stayer
Stayer
OT for others to answer: Is Hackish still doing ECU work on the Lancer? Is the ECU interchangeable between cars...I have 2 4G69 Ralliart ECU's and would like to send one off for re-flash if it is just plug and play in any 4G69 RalliArt. I suppose I could test it...
My reflash is $ 300. There is no need to send the ECU in Russia. I will do everything through the Internet and the program Team Viewer. You only need the cable Tactrix. And turn the ignition on.
I've done this on the 4g club. There's only one small problem. I'm on the other side of the planet. The time difference of 9-12 hours. But it's solved. If you are interested, write PM.
PS The camshaft kit I put in the kit. However, if you only do mechanical work, without reflashing. It will be $ 400.
Resurrected RA (Jul 6, 2016)
Will your re-flash work with the Lancer RalliArt ECU? If not, what would be the cost without the re-flash?
I'm definitely interested in this camshaft kit but I need to iron some stuff out first with the car before I can focus my energy on it. (Rpms climb along with coolant temp after extensive driving)
I want to make sure I'm understanding correctly.
$400 for cam & rocker?
$600 for cam rocker and reflash?
does this work on an untouched ecu?
what cable specifically do I need? (Part number would help)
how do I pay/ship?
thank you
how do I pay/ship?
thank you
My payment through PayPal. If you will send parts to me, I will write you my address.
You understand correctly. This will not work without flashing. Your valves are longer in the open state. In this case, the cylinder gets more fuel-air mixture. It is necessary to adjust the ECU. Can do I have or can do Hackish. Write to him, tell him what Stayer said to contact him.
I will be looking for cam, rockers, flash, and crank pulley and a package.
Thank you again
stayer (Feb 26, 2017)
So it is necessary to download and install on the laptop from the link below EcuFlash 1.44
http://www.tactrix.com/index.php?opt...d=36&Itemid=57
Download and install the program team viewer.( teamviewer.com)
Resurrected RA (Feb 27, 2017)
How can I purchase crank pulley
How can I purchase crank pulley ?
QUOTE=stayer;11633848]It is possible to buy. It costs 600$. Price includes: Work with the camshaft. Work the rockers mivec. Reflash ECU.
Stayer[/QUOTE]
Stayer[/QUOTE]
Payment process
786 909 0039 this is my cellphone call or text with payment processing info
QUOTE=stayer;11633]It is possible to buy. It costs 600$. Price includes: Work with the camshaft. Work the rockers mivec. Reflash ECU.
Stayer[/QUOTE][/QUOTE]
