Idler pulley question?
Hey guys!
Its been raining here a lot in California and recently the car has started a belt squeal noise when it's cold in the morning.
I recently replaced the belt, currently running a road\\race UDP on the crank. I put it up and jacks thinking it was the power steering pump.( which it wasn't). I sprayed some grease on the upper idler pulley and auto tensioner and the sound is gone and cleaned the area up.
I can find the auto tensioner on rock auto but can't locate the upper idler pulley( it's right below the upper motor mount) on the site.
Any suggestions on where to find that idler pulley?
Hey guys!
that's your water pump
replace tensioner w/pulley and belt (if they're old, seized, or worn), while the old belt is off, check to see if the idler or any pulleys (accessories) are seizing...they should all be pretty easy to turn by hand, except for the crankshaft, obviously. could just be the belt, you sure you have the correct length belt for the UDP? is there obvious damage or excessive wear on the belt? and if so, where?
I just had a similar issue with my belt after UDP was installed. Below is the link to my post, maybe it can help.
https://www.evolutionm.net/forums/04...lt-issues.html
on a side story. I had 2 gates belt shred on me. Timing belt went and sepretine belt all in one month. Which destroyed then engine. So I stay away from gates.
fsc0224
Mar 5, 2014 02:10 PM
Zman15
May 11, 2010 12:41 PM
scorke
24
Dec 12, 2006 09:01 PM
