OEM Ralliart Part Number Questions
#275
I put an 04-06 Ralliart rear spoiler on my Evo, but I need the third brake light that gets mounted in the spoiler itself.
I see that MN126920HB is listed, but it's unclear to me if that part number is for the 3rd brake light that fits in the spoiler, or if that is for the one that goes in the passenger compartment up against the rear window.
I've also found MR522039, which is significantly more expensive.
Any idea what I need for the 3rd light on the actual ralliart spoiler?
Thanks, in advance.
Thanks, in advance.
#276
Thanks, in advance.
Thanks, in advance.
#277
I need an abs speed sensor and because its 270 dollars everywhere roughly, I'm gonna search some junkyards. I know the oz has the same kind of sensor and connector but does anyone know what other trim or vehicles are the same?
#281
i tried to remove mine so i could completely remove the knuckle to givemyself more space to work, but the thing would not come out, and actually broke a little piece off the mounting hole, so i just stuck the bolt back in and said **** it...so no i just hang the knuckle with wire or whatever for hands free.
#282
#283
Sry i left out i need front left. I was able to get the passanger side out after a long episode of light taps and jiggles but the driver side broke stupid easy. Thanx for the PNs though and I ended up finding it fits all trims but the evo anyway. So far I haven't found a junk yard that has any lancers period.
