OEM Ralliart Part Number Questions
#289
Part number for the oem airbox?
Gonna cut the mass airflow sensor tube out of it and use it for my DIY intake just don't want to cut my airbox up.
Or if anyone wants to sell me theirs
#290
don't cut it, get the piece from an Evo X airbox, same MAF housing but it's not attached to the air box. well it is attached, but it's a separate piece...08+ lancer guys use it for DIY cold air intakes...
i can't pull a part number for you...my ASA doesn't have the X in the database...
EDIT:
k, found it....item 14 if that link works
http://www.trademotion.com/parts/201...iagram=6267190
EDIT:
#291
EDIT:
EDIT:
#294
#297
I dunno the part numbers but I ordered mine off mitsubishiparts.net I needed them cause the stock ones were just about rusted away and I sheered off bolts holding the bracket on and studs in the brackets... It was a major pain... But well worth it.
This LINK should take you to the page where you can find what you'll be needing.
