car wont go over 3,000 RPM
hey guys i have an 04 ralliart. while trying to maintain a constand speed, the car seems to start to bog down..like the engine is losing power. it happens randomly.
after driving it for a couple days this way, i was getting off of the highway and the CEL light comes on, i have to mash the pedal to even get to 20 MPH. the car has no go to it at all.
whether the car is in gear or not, it wont go above 3,000 RPMs. if im in neutral, and i put the pedal to the floor the rpms raise very very slowly. it seems that if i let the car sit for 10 minutes, the problem just disapears. has anyone else had, or heard of this problem?
also, i went to autozone and pulled a code. the ink on the reciept they gave me rubbed off, so i dont have the actual code, but the description was "open or closed circuit. or Pedal positioningsensor" The guy at autozone acted like he didnt know what the hell any of it meant.
thanks guys
thanks guys
i will check that today, could that really be causing all that trouble?
my problems sound very similar to this now that i looked around more:
https://www.evolutionm.net/forums/04...er-rain-2.html
but mine doesnt only seem to happen in rain..
APP Sensor is your culprit. Unplug it and apply some di-electric grease on it. If that doesn't help with the problem you're going to most likely have to buy a new one.
P.S. Hot Carl is a funny *** name.
As for the dielectric grease thing I might skip that Crankswick has confirmed that it acts as more of an insulator. It restricts the flow on the connectors rather than making it easier. RalliartN had some insightful knowledge on this.
I know the idea behind using grease in electrical connectors is to stop corrosion, but don't do it. Dry, clean, shiny (i.e. oxidation sanded off) is the best. I've done plenty of electrical bulb and connector troubleshooting where someone has used that grease and all it's done is inhibit conduction and made the part stop working or work intermittently. If grease is used and the connection seems to work it's in spite of the grease as metal-to-metal contact has cut through the slime, and this doesn't last long.
If there is a particular connection that seems to corrode often, well, add cleaning it to your maintenance list of things to do more often.
just had the same issue the other day ... it was the APPS ... a couple pose up with the picture. noticed that the car ran even better before i even had the issue
I had this issue once every 2-3 months (sometimes in pairs within a day) I'd lose all power and have to slam the gas pedal to get the car into a parking lot at 2500 rpm driving through what felt like quick sand.
The dealer reflashed my ECU and not only did that fix it, the car sounds and feels meaner now too ha. I forgot what my check engine code was but when I gave it to the dealer they found what the reflash was for it.
