Cold Spark Plug Knowledge
Measured the lengths with vernier calipers - used to be a machinist, so I have all zee tools. It's like Cranswick said, length from under the gasket to the tip of the skinny iridium electrode.
And I don't rely on luck... I read
The threads are dark, but the ground prong and the ceramic around the electrode are uniformally coated in a fine white-ish ash. No metal particles, no electrode wear. Gap is 0.035". Still good for another 50,000 km.
ok this may newbish but I've read the thread and I believe I need to replace my plugs a.s.a.p. my questions are... with no major mods done to my car do I need to do any other things while I'm there aside from just taking out the old and putting in the new plugs? I plan on getting the NGK LFR7AIX plugs on amazon I found them for a good deal but says they don't fit?
there's no need to run colder plugs with little to no modification...**** you can run copper plugs...but iridium is by the book...
Amazon FTW!!
Thinking about it now, of course the NGK tech department knows **** about the plugs they designed - shame on me for letting them fool me. It looks like I've made a huge mistake running'em for a long time successfully in an engine I hammer hard.
...nothing personal, I understand your question ...I get sarcastic after I do really thorough work and it gets trumped by Amazon as the authority?!?
So as you said, Cold spark plugs are good for modded cars. I am planning on adding a cold air intake. Was wondering do I need the cold spark plugs. (Probably the only mod, maybe some tuning in the future)
Also is it bad to run cold spark plugs if the car is stock. Does one give you better mileage (I don't think so)
cold air intake is hardly modding...basically, you don't need colder plugs unless you either increase compression, or increase intake manifold pressure (as in forced induction) which will produce more power, and increase combustion chamber temperatures...also if you do any tuning, specifically advancing ignition timing, you could benefit from colder plugs...otherwise you're just spending more money than necessary...
Yeah, our best bet is to trust the 17 year old auto parts "expert" inputting info into the Amazon database.
And I'm sticking with the stock plugs on my stock engine.
Well seeing how people already had questions with the plug in the very beginning and there was no clear answer as to whether or not anything different needed to be done, I feel the question was legitimate. I never said you were wrong and amazon is right I just wanted clarity.. and if you're so bothered by it days later when someone already answered all I needed then maybe your just a jackals and not a smart ***..
easy now, I think the issue is that informative posts like these take time, research and money from our own pockets to bring the knowledge to the masses, and your doubtful reply simply struck the wrong note with a few of the regulars because of that...we're here to bring knowledge, not bull****, if there were any doubts about the validity of the information, I (or someone) would have called them out already cheers...
Lightsaber
Jun 9, 2017 07:40 PM
