tps problem
tps problem
people i had a tps problem so i bought a new one and its still giving ME THE SAME problem... i scanned the car everytime and it says something about low voltage on the tps..
HOW CAN I FIX THAT PROBLEM??
THANKS FOR YOUR HELP
You bought a new throttle body? Or a new Throttle Position Sensor? The position sensor went bad on mine. I had to replace it before it started acting correctly. its on the left side of the engine bay the throttle wire goes over to it. Here is the part. Part # is in the pic.
the symptoms are bad idle, car doesnt pass 2000 rpm full throttle, thats basically it
Ok earlier you had replied to crans saying you had gotten a new TB. Thats why i went back to the APPS. When mine was having this issue it was saying both the APPS and TPS were the problem. I replaced the part above at the request of otter and it fixed it. If that's the part you got and its still messed up get a new throttle body. Like crans said the little black box on the TB is the TPS. Either a TB from a ralliart, 4g eclipse (i4 or v6), or a 4g69 galant will work.
the APPS is also adjustable, but why? and what is the outcome?
When my APPS when out last year, the symptoms where when cruising at about 40 or so, I could feel stuttering as if the car was jerking slightly. Not much but enough to notice. I didn't have any issues with idling or acceleration. After experiencing this for about 2 months it died complete and threw a -> P2138.
i already metered the wires, at first they are at 5v or more and then go down 2.5-3.2 :/
