Engine Help
Engine Help
Hey People
Sorry if this is the wrong place to post this (closest to 2001 ralliart i could see, and my first post to the site :S)
i have a 2001 cedia lancer ralliart wagon and just weighing up options atm cause my engine is broke :S
it has a 4g93 GDI turbo tiptronic in it now, im thinking of an engine and manual trans conversion that's not evo (cant afford atm).
i want something with a tiny bit more grunt, as ive previously had a 4g92 mivec which makes my current car seem not so great especially since its a wagon and carrying more things now a days for work.
A few people have suggested to me i should put in a 4g93T because it would apparently bolt straight in and it doesn't cost an arm and a leg.
if anyone has other better ideas or can help it would be awesome!
P.S im really sorry if i sound dumb and noob...its cause i really am
Hello, welcome to the forum.
Your current engine is a turbo charged 4G93 with GDI (Gasoline Direct Injection ? ) and you want to change to a different turbo charged 4G93, correct ?
Which one, the one from the baby evo ?
Without more information I cannot comment, why would the other 4G93 be better than what you had ?
I can only think of the 4G64 or 4G69 as alternatives but neither sounds better than a turbo charged 4G93 stock to me.
A 4G92 doesn't exactly ooze bottom end torque and you mentioned the car is used for work, so that would definitely be unsuitable, since torque is an engine's ability to do work.
Post up some more details is all I can say for now.
thanks for the reply
yeap at the moment it has a 4g93 GDI turbo
which the specs are as follows
4G93 http://en.wikipedia.org/wiki/DOHC 16 Valve GDI Turbo
It was suggested that i should put THIS engine into it if i wanted just a little more power and also since its a straight in/out conversion
4G93T http://en.wikipedia.org/wiki/DOHC 16 Valve Turbo
the car is my daily car, but i suggested work because i use it to travel to work and i often have stuff i buy from work in my car and forgotten about thus....end up carrying more things haha
- Gasoline Direct Injection (GDI) with turbocharger
- Total Displacement - 1834cc
- Bore - 81.0mm
- Stroke - 89.0mm
- Compression Ratio - 10.0:1
- Maximum Output - 118 kW (160 PS; 158 bhp) @ 5,200 http://en.wikipedia.org/wiki/Rpm / 121 kW (165 PS; 162 bhp) @ 5,500 http://en.wikipedia.org/wiki/Rpm
- Maximum Torque - 220 N·m (160 ft·lbf) @ 3,500 http://en.wikipedia.org/wiki/Rpm / 220 N·m (160 ft·lbf) @ 3,500 http://en.wikipedia.org/wiki/Rpm
- Multi-Point Injection (MPI) with TD04 turbocharger
- Bore - 81.0mm
- Stroke - 89.0mm
- Compression Ratio - 9.1:1
- Maximum Output - 158 kW (215 PS; 212 bhp)
- Maximum Torque - 284 N·m (209 ft·lbf) @ 3,000 rpm
Sorry to hijack this thread!
I had a 4g93 gdi before. I just swapped to a 4g93 forged lower block with a pnp 4g92 mivec head.
apparently now my oil temp goes between 104 when cruising and 117 (currently road tuned with mivec off).
My mivec is off because when the oil temp reaches 101, the mivec sounds like a motorboat. But below 101 its opens properly.
Oil pressure when idle is at 2.0 but had to set the idle rpm at 1350 to get that else it'll be 1.7 with the motul 15w50.
Anyone faced this issue before?
Ive been advised to:
1) put an oil cooler.
2) change the mivec solenoid and see if the mivec is rectified.
3) if 1 and 2 dont work, means theres issue with the rocker deck.
please help! Am desperate haha
Well it was 2.5bar oil pressure when i took it out from the garage. He used 20w50 castrol oil. After about 1k km run it, i changed to motul 15w50 and thats when the oil pressure at idle when down to 1.8bar. And when shifting gears it'll drop to 1.2 or lesser.
Oil temp also goes beyond 100 degrees celcius during idle and crusing it hits around 103.
Reall am lost at what to do now. Dont wanna spend too much too tho.
I dont have an oil cooler.
But i can't help but think that theres an underlying problem somewhere.
when it was on GDI 4g93t my oil temp never went pass 90+. Can't say much for the oil press as i was using an ultra gauge then lol.
i guess ill swap out the mivec solenoid and add an oil cooler and monitor!
If this doesn't working, my tuner mentioned that it could be an issues with the rocker deck.
What are your thoughts? And do you get such temp and oil readings too?
