Galant Ralliart Tranny swap, (auto to manual)
Old Jul 16, 2015, 05:48 AM
GalantRalliart5's Avatar
Any one know how much of a pain and if it's worth dropping a manual tranny into my Galant Ralliart?
Old Jul 16, 2015, 06:57 AM
2006_RA's Avatar
Welcome to the forum.
This is a 6G72 ?
I cannot imagine it would be painful. Research it and source the parts from junk yards and it would be a great summer project.
Parts needed off the top of my head:
ECU from a manual (may need a different wiring harness)
Pedal Assembly
Clutch/Brake master cylinder
Clutch line and slave cylinder
Gearstick and shifter cables
Gearbox
Flywheel
Clutch
Pressure plate
Throwout bearing
On the Lancer Ralliart the manual and automatic share axles you may be lucky like that on the Galant. Your research will answer that.
Good luck and let us know how it goes either way.
Old Jul 16, 2015, 07:50 AM
bakuro117's Avatar
I believe the tranny bell housings are different between the 4g and the 6g series. Otherwise there would be a LOT more AWD v6 eclipses over on Club3g and Club4g. You would probably have better luck with a manual tranny from a fourth generation (2006-2012) Eclipse GT.
The parts list should be the same as what 06RA listed. And he is right the wiring harness will be different. i ran into that issue when considering the auto to manual swap on my RA. There are different plugs and things on the tranny and for your pedals.
Old Jul 16, 2015, 08:58 AM
This is a 6G72 ?
Pedal Assembly
Gearbox
Flywheel
Clutch
Pressure plate
Throwout bearing
It's got the 6G75 MIVEC in it, that change any of your thoughts?
Old Jul 16, 2015, 10:29 AM
2006_RA's Avatar
^^ Yes, that makes it more exciting .
Old Jul 16, 2015, 11:10 AM
Tranny's are a whole new demon for me haha, any you guys would recommend to look for specifically, I found a Miata 6 speed on eBay for $550 and I'll do all the work in the shop I work at with my lead techs help. Just want some thoughts before I pull the trigger on something like this
Old Jul 16, 2015, 11:15 AM
bakuro117's Avatar
You'll need this^
Good luck finding anything else to bolt up to a 6g75.
Old Jul 16, 2015, 12:52 PM
2006_RA's Avatar
Miata ????? What how *&^%#%&* gulp.
Search online for the 6G75 and vehicles that would have had it with a manual gearbox.
http://car-part.com and search for a manual 2006 Eclipse like Bakuro said.
Old Jul 16, 2015, 12:57 PM
Haha that's why I asked
Old Jul 22, 2015, 08:58 AM
floating doc's Avatar
I dream of a manual transmission in my 04 RA Sportback. I haven't seen anyone do a writeup on a lancer swap.
It's my daily driver and I work 50-60 hours/week. Not at all likely to happen...
Old Aug 1, 2015, 07:52 AM
nekkidlad's Avatar
just wait for bakuro to do and write-up his swap...lol
his isn't a sportback but it's still a RA with auto..(aka same thing)
he's got everything he needs xept time and an extra working car for the downtime(anymore)
Old Aug 3, 2015, 09:16 AM
bakuro117's Avatar
FACT.
TheChampiYon
Dec 21, 2020 05:43 PM
LancerBoy2004
25
Jun 8, 2012 06:03 AM
dspucches
Lancer Tranny/Drivetrain Tech
Feb 17, 2011 11:57 AM
Lancer2oo3
Lancer Engine Tech
Apr 6, 2006 09:41 PM
Quick Reply: Galant Ralliart Tranny swap, (auto to manual)
