New fuel pump, car wont start
Old Jan 20, 2017, 06:57 PM
Mycarwontstart's Avatar
Question New fuel pump, car wont start
I have got an 06 ralliart, and one day the car wouldnt start. I didnt hear the fuel pump engage, so I replaced it and its got power and it hums. I took the hose off the pump and it sprayed gas out of it, so there is pressure in the tank. This didnt solve the problem though. I pulled the spark plugs out and two of thw four springs in the coil packs were wet. The corresponding plugs had a little liquid that looked like oil on them. The other two were fine however. I pested for spark and there was none. How would I resolve this?
Old Jan 20, 2017, 07:05 PM
4b11slayer's Avatar
So you have no spark in any of the cylinders? How was this tested?
Have you checked fuses? Every single fuse should be checked as step 1.
These newer cars have coils and do have fuses.
Good fuse. Both legs have power.
Bad fuse . One leg has power.
No power to either leg, Circuit is not loaded at the moment.
Old Jan 20, 2017, 07:09 PM
Fuses looked good and i tried new fuel pump relays. I tested spark by taking the coil pacls out and I stuck a screwdriver in there while someone cranked it. I tried keeping the screwdriver in different distances from the spring inside and there was no spark at all. Then I took the plug out of the head and put it in the coil pack and it wasnt arcing. I tested it both before and after I cleaned them up a bit
Old Jan 20, 2017, 07:16 PM
4b11slayer's Avatar
Did you just look over fuses? or did you use a volt meter or test light?
Can be a crank shaft/camshaft position sensor fault. Have you scanned for fault codes?
Old Jan 21, 2017, 01:05 AM
I do not have a volt meter. And if the crankshaft posotion center was bad, wouldn't the check engine light be on? The check engine light is not on. I have a buddy who has a multimeter that I can use tomorroe. I'll post updates when I get them
Old Jan 21, 2017, 01:31 AM
4b11slayer's Avatar
Well the car doesnt run, how do you know the light isnt on.
Old Jan 21, 2017, 01:36 AM
Thats a good point haha. It doesnt turn on when in accessory, but now that I think about it, it wouldnt do that anyways. I'll get my hands on an OBD II scanner as well
Old Jan 21, 2017, 01:46 AM
4b11slayer's Avatar
Lol. Yea it should still turn on everytime as a self check. So get it scanned and check fuses.
Old Jan 21, 2017, 01:56 PM
spoolin turbo's Avatar
Scan the car. That's the only way. What pump did you replace it with?
Old Jan 21, 2017, 09:48 PM
CrAnSwIcK's Avatar
the check engine light comes on when the key is in the on/run position, it stays on for I think 20 seconds if you don't start the car, and then goes out if there are no faults, if the engine is started, and there are no faults, the light will go out immediately...not sure if it comes on in accessory, but I think not.
when you tested spark, did you ground the body of the plug to the engine or chassis? if not, you would have no continuity...
BadassEvo8
Nov 26, 2014 10:19 PM
ohEVO18
12
Mar 19, 2010 02:56 AM
ohEVO18
Mar 17, 2010 08:47 AM
Randog
Sep 10, 2009 04:41 PM
BMWE30
10
Dec 16, 2006 09:18 AM
Quick Reply: New fuel pump, car wont start
