Grounding Kits for Ralliart
I don't really want to spend a whole lot of money on grounding kits. But I've noticed there was a diagram in the EVO forum on where the ground wires suppose to be.
I would like to make my own but I'm not sure where to connect the grounds. I already made my own little 8 gauge grounding from the negative part of the battery to the driver chassis, which is about 6 inches away from the battery.
So if anyone knows where to install the grounds, much appreciated. Thanks.
bumpity bump
Originally Posted by Daddymac
Just a quick question...what difference would the grounding kit make on the RA? I've already noticed that the idle is somewhat erratic.....does it help that?
There are 6 piece of 8 gauge wires. Lengths = 36.5", 27.5", 18.5", 10", and 8". I bought some gold plated terminal rings from autozone.
I noticed when going 70mph, my rpm is at 3000-3200 instead of 3400-3500. The stock stereo sounds like it's been amplified. Idle is good. Smoother excelerations.
Again, my car is still stock. This is the only mod I've added.
The rpm difference sounds a bit fishy; but I'm still interested in redoing the grounds on my car. The couple of questions I have are...
1. Where do the different lengths of wire connect; I'm sure I could search the car, but it would be nice if I didn't have to. If you have the time please post detailed instructions.
2. Would replacing the wires affect the warrenty in any way, I know that they can be sticklers on some issues.
Thanks
Thanks
first off, look above.. he has the lengths in there in inches... secondly you are tampering with the electrical system.. so if anything you will lose the warranty on the electrical system if you dont remove and replace with stock before going in for warranty work... or you could call your local dealership and see if they will accept it before you install it...
Mitsubishi DOES offer a grounding kit for the Ralliart. If you buy it from them then you wont have to worry about your warranty. It will be more expensive than doing it yourself but it might be worth looking into.
I am going to make one for my car and install it, maybe this weekend. I printed out the instructions that where posted in EVO section. I can make kits for people with instructions if there is enough interest.
If interested, PM me.
does anyone know how much the grounding kit from mitsu is? if it's like the grilles there trying to sell i'll say screw it. but if it aint to expensive then i'll def get it. jeddi you said it changed the rpm at 70 mph. are you sure about that. i hope you are cause that equals better mpg.
