how to change fog bulbs
Old Jan 16, 2007, 11:01 AM
insomniac_evo's Avatar
took about +- 30 mins to change
1st: take out the splash guards
2nd: there's 2 holes in front of the fog lights, take your screwdriver and remove the bottom screw
the top screw is for adjusting the fog lights
3rd: push the fog lights in slowly, it'll just come off and remove the cable
when installing back the fog lights, theres 2 holes that you can fit the fog lights in, its like hinges
thats the fog light after you take it out, then take out the 3 screws, watch out it strips damn easy
insomniac_evo is offline
Old Jan 16, 2007, 11:02 AM
4th: pull out the bulb connector, its under the rubber hose, its a little bit tight
5th: take out the screw thats holding the retainer, you're going to use it again to hold the bulb in, dont lose it, it'll jump out once you loosen the screw
old bulbs out
new bulbs in, theres a yellow tint now
Cncr (May 11, 2016)
Old Jan 16, 2007, 11:04 AM
VOila...my headlight is a 6000k hid, i'm changing to 5400k soon
Cncr (May 11, 2016)
Old Jan 16, 2007, 11:10 AM
Myszkewicz's Avatar
Good write up.
My only other comment is that it's not necessary to remove the screw for the bulb retainer. You can unhook the other ends of the retainer and swing it out of the way without removing it. I've done it while laying on my back under the car, should be easy with the light in your hand.
Myszkewicz is offline
Old Jan 22, 2007, 02:59 PM
EvoM Administrator
otter's Avatar
Closed and stuck. Discuss here.
otter is offline
Heliart
15
Oct 2, 2023 02:33 AM
MasterAK
Lancer How Tos / Installations
58
Aug 19, 2020 10:45 AM
FiReBReTHa
Jul 9, 2020 06:03 PM
EvokidIX
Mar 12, 2016 04:08 PM
Trueno86
For Sale - Wheels / Tires
Jul 22, 2009 09:39 AM
Quick Reply: how to change fog bulbs
