HOW TO: Install A/F Guage
Old Mar 18, 2007, 06:24 PM
redlne8's Avatar
This is a general "How To" on installing an A/F guage. -
Tools needed:
*18 Guage wire
*Wire Nuts/Electrical Tape
*Wire Stripper
*Drill
*X-ACTO Knife
*Patience
1. Start out by routing the RED wire from your A/F guage to a +12V ignigion supply
(a very easy tap would be to your ACC line on your car's CD head unit).
2. Route the black wire to a good ground connection and secure tightly.
3. The third wire will be the one we use to tap into the O2 sensor. You will need to drill a small hole in your firewall to route the wire down through your engine bay and back to the O2 sensor (I drilled mine right below the throttle cable). Be careful the wire does not get too close your your exhaust piping! For this step I did a "cheater" way if you are leary about actually splicing or cutting anything. You want to pull the sleve cover back and then shave the insulation off the BLUE wire of your O2 sensor. Once you have a good inch of wire exposed wrap the last wire (that you routed) from the A/F guage around this exposed portion and tape up tightly to prevent moisture. Slide black sleeve that cover O2 Sensor wires back over and your done.
-Matt
redlne8 is offline
Old Mar 18, 2007, 08:31 PM
EvoM Administrator
otter's Avatar
Couple notes on this. It's for a narrowband A/F meter, not wideband, and you dont' need to drill a hole in your firewall. There are already many holes there stock for us to use.
Discuss here.
otter is offline
cij911
139
Mar 19, 2021 04:19 AM
ZWingerRyRy
Evo X How Tos / Installations
267
Apr 22, 2020 04:26 AM
mrwickd123
11
Nov 2, 2016 10:19 PM
Grimsta
Aug 11, 2007 01:03 AM
rhyzin
Lancer Engine Tech
Aug 15, 2006 02:37 PM
Quick Reply: HOW TO: Install A/F Guage
