Lancer Mini Battery kit install
Old May 29, 2007, 09:55 PM
ThyPunko_PR's Avatar
This is the install of the PPI Lancer Mini Battery kit:
Tools needed:
10mm open wrench
8mm Allen
6mm Allen
5mm Allen
Red Loctite (271 or 277)
1st: Remove the 0EM battery.
2nd: Remove the plastic tray: take care of removing the rubber line attached to it. There is also a plug attached to the lower corner of the tray. This will be a good time to clean the area below the tray.
3rd Install the lower part of the mini battery tray with the provided adapters using the 8mm Allen, you will use the two big holes were the plastic tray used to be:
4th: Install the 0dyssey PC680:
5th: Secure the battery with the top part of the tray using the 6mm Allen:
6th: Install the battery terminals with the 5mm Allen (put a small drop of loctite in the threads of the battery post cap screw) . Take note that the bigger one is the positive side (+/red) terminal. Then install the positive and negative cables and secure them with the 10mm wrench. ENJ0Y!
ThyPunko_PR is offline
Old May 30, 2007, 10:07 AM
EvoM Administrator
otter's Avatar
Closed. Discuss here.
otter is offline
seven10
For Sale - Wheels / Tires
Apr 4, 2017 09:36 PM
jlldetroit
Aug 11, 2016 07:14 PM
pog0
Jan 23, 2016 05:31 PM
Curt@MrLed
Jan 4, 2008 07:13 PM
propellerhead
Oct 15, 2004 07:23 PM
Quick Reply: Lancer Mini Battery kit install
