Trunk Hole Plugs
Trunk Hole Plugs
hey guys, i totally forgot i was going to post this up for a few guys here on the forums (my apologies). this is for when you go wingless and done want those ugly holes in your trunk. also looks a whole lot better then using tape or some other ghetto crap like that. lol
you can get all this stuff at your local lowes/home depo
heres what you need:
1 x 1/2 inch nylon hole plug.
6 x plastic fir-trees
clear silicon sealant
sandpaper
paint to match your car and clear coat
First take off your wing. easy enough.
now after you do that you will see the 4 holes from the bolts, 1 bigger hole where the rubber grommet and the wire(s) for the brake light in the wing goes, and two other holes that have black plugs in them.
take out the black plastic plugs, do be careful though you could mess up the paint around the edges of the trunk hole.
after thats done, clean up the area where your wing was bolted down to the trunk. it may be dirty or discolored from water getting under the wing and sitting there forever. using a clay bar, some wax and a quick buff should do the trick.
now its time to prep the plugs.
take the 1 larger nylon plug and the 6 fir-tree plugs and use the sandpaper to rough up the tops.
stick them either in a box or folded piece of paper...something you can use to stick the plugs straight into so that you can spray the tops with the paint that matches your car color. i just took a oil filter box, punch some holes in it and pushed the plugs into the box.
then spray the tops of the plugs with your matching car paint. do a few coats. then after wards use the clear coat for a few coats.
after the plugs are all nice and coated/clear coated. take the clear silicon sealant and put some on your finger, rub it to the underside of the plugs (thats the underside of where you painted) and try not to use too much, just enough to when you place it in the trunk hole it will seal all the way around, and not too much where it comes out from under the plug when you press it down.
for the one bigger plug for the bigger trunk hole, just put a litter around the sides. this 1/2inch plug is the perfect size for that trunk hole, but it dosnt really have a edge like the fir-trees plugs.
after everything is done, your trunk holes will be sealed, no water or crap will get into your trunk, and it will look like some nice painted rivets in the trunk. not the crappy colored tape look
ill post some pics tomorrow morning, its too dark to take pics.
also if you ever have to take out the plugs to either re-paint them or you want to install your wing again, use a plastic scrapper or you will def mess up your paint.
let me know if you have any questions.
-Flip
sandpaper
-Flip
good writeup
you just had to call out my ghetto tape didnt ya? dickk! lmao jk but i will definitely look into this. where did you get the paint? i've been looking for touchup paint for the car but all the pens they sell at autozone none are for mitsus =/ is dealer the only place to go?
good writeup
for the paint, i had the same problem, i just got to the closest color to the white as i could get, but turns out those paint pens suck...big time. after a few tries, the paint with those pens would just break off and just suck. so i said F*** it and got some actual spray can paint and went to town. its held up though many car washes and the rain. still looking good.
-Flip
hey flip im getting ready to do this too i think getting kind of tired of the wing
is there a specific size to the "fir-tree" plugs? or is there pretty much only 1 standard size that you saw? might try to find something that will actually fit flush inside the whole to keep the trunk as smooth as possible without too much work. hopefully get it done in the next week or so and get some pics up
you dont want them to fit exactly the hole size, you want the cap to extend over the hole a little bit so you can apply some clear silicon sealant, so it seals the trunk and no water gets inside.
-Flip
thanks for the write up OP. i wouldn't have ever thought of this if it wasn't for me finding this thread via Google. i was originally going to use electrical tape and color matching it to my car, but this by far is the best solution i've found. car is definitely nothing compared to an evo, but i hated my wing and i decided to take it off yesterday. here are some pics of the results:
BEFORE:
AFTER:
BEFORE:
AFTER:
hey no problem bro, nice job btw on your trunk hole plugs, they turned out nice. yea the electrical tape method is hella ghetto. and if you want your spoiler back on, you dont have to have someone re-drill the holes.
-Flip
-Flip
eehjay
Lancer How Tos / Installations
Nov 3, 2007 07:33 AM
proverb
Sep 24, 2007 11:38 AM
