Driver Seatbelt Chime Delete
Old Aug 30, 2012, 05:59 PM
RacerX-Ralliart's Avatar
Very nice write up with a lot of information on how stuff works.. This is pretty cool.. My car doesn't chime though might have been "fixed" before hand.. Maybe 2004s didn't come with it?
Old Aug 31, 2012, 05:21 AM
RalliartN's Avatar
Originally Posted by nerdbotSKRA
Scofflaw, my best guess is: Someone who scoffs at the law
As for retirement age, think it's 65 with an option to continue working until either age 71, or until 35 years of service.. (That could just be for Sask. though)
I'm 21 so don't quote me on this, old enough to know but too young to care haha
^^ True
My age? I'm 20 trapped in an over-50 body.
Old Aug 31, 2012, 06:36 AM
CrAnSwIcK's Avatar
Originally Posted by RalliartN
^^ True
it's ok, i've been 16 for the last 10 years
Old Aug 31, 2012, 06:42 AM
Bobrick's Avatar
You can also just disconnect the plug under the seat for the seatbelt.
Old Aug 31, 2012, 06:53 AM
Anarchy99's Avatar
reflashing in older rom files to the ECU will delete the chime also. I think that didnt become mandatory until 2005-2006 as teh 2003-2004 Evo's don't do it and the newer ones do... All in the mapping.
Old Aug 31, 2012, 07:12 AM
2006_RA's Avatar
Hmmm, now about those pesky airbags...
Go Nick, removing mass is like adding power plus there is an inherent handling benefit.
Also, I find steering wheels rather distasteful now that the big lump sits there dominating the middle of it.
Who really wants to sit with an explosive device inches from their precious bits anyway ?
Old Aug 31, 2012, 07:56 AM
CrAnSwIcK's Avatar
you guys are too much...
Old Aug 31, 2012, 07:57 AM
nerdbotSKRA's Avatar
I sure don't.
Airbags hurt me
Old Aug 31, 2012, 08:36 AM
Dolfandrus's Avatar
well done.
Old Aug 31, 2012, 08:52 AM
RalliartN's Avatar
Originally Posted by lanzerralliart
by my calculations I'll be able to retire 5 years after I die
In reality, I'm on the "Freedom 95" plan too!
Old Aug 31, 2012, 09:48 AM
nekkidlad's Avatar
and now the SRS light in the dash is on
SRS light should go out after the next ignition cycle...SRS system always does a self test at start up(when all the dash lights come on then go off after a few secs)
...if it's on, there's a problem...you can't clear it...and if you can somehow, it'd come right back on till you fix it...
Old Aug 31, 2012, 10:30 AM
bakuro117's Avatar
Time for this to be made into a sticky?
Old Sep 2, 2012, 09:05 AM
CrAnSwIcK's Avatar
are you sure? cause when i unplugged my passenger seat to clean the carpet underneath, i've had an SRS light ever since, and it's all plugged back in, nothing has changed...can't be a coincidence...
Old Sep 4, 2012, 05:21 AM
nekkidlad's Avatar
all srs/airbag systems do a self check on every ignition cycle...
if there's sumn wrong it'll come on...if it's all good, it shuts off
Old Sep 4, 2012, 08:09 AM
CrAnSwIcK's Avatar
maybe it's different on the 06 ECU, cause i have the same problem as Nick, our ECU's are canbus, and there were no problems prior to unplugging the seat...there's no way that something failed at exactly the same time...Nicks car is still pretty much brand new, i highly doubt anything is even close to failing/malfunctioning on his car...
Quick Reply: Driver Seatbelt Chime Delete
