Aggressive Wheels on 2004-2006 Lancer
Old Jun 12, 2014, 07:31 AM
  #541
Bcuzlancer's Avatar
Originally Posted by lancer 12
Yeah I had a yellow one but my friend crashed it and now I have a Ralliart and a regular 03 Es
Sweet dude thats awesome!
Old Jun 12, 2014, 11:24 AM
  #542
EvoM Super Moderator
lanzerralliart's Avatar
So I have some rims 17x8 +35 for the front, I'm planning on running those with a 215/40 tire the drop is like 1.5" (progress springs) I don't see any issues there. What do u think?
Now the fun part the rears are 17x9 +43 planning on same size tires 215/40. The drop os only .5" according to progress but it looks like its raised. I was thinking 15mm spacers to get it in a safe zone , would an extreme pull be needed at that offset? Maybe 10mm?
Checkout my thread for some pics , and I would really appreciate any help guys.
Old Jun 13, 2014, 08:18 AM
  #543
2006_RA's Avatar
Hi Lanzer, I for one cant wait to see how you work out the rears>
In the mean time here's a nice calculator with diagrams too:
http://www.willtheyfit.com/index.php...et2=38#content
Old Jun 13, 2014, 10:56 AM
  #544
I'm confident I can get it all to fit nice . I even found a guy that rolls fenders so much and so good he's called THE FENDER ROLLING KING OF MIAMI. Lol. I really am just debating on the color of rims...
Old Jun 13, 2014, 10:58 AM
  #545
lancer 12's Avatar
What's the stock width on the Ralliart's wheels?
Old Jun 13, 2014, 11:18 AM
  #546
2006_RA's Avatar
16 x 6 ET 46
Old Jun 13, 2014, 01:58 PM
  #547
MirrorEyes's Avatar
I run 17x8 +38's (w/ 215/45 rubber) and the back definitely needed a roll on stock suspension. With the 215/40 you should be fine in the front, but you will probably wanna at least roll the fenders at the back. Maybe a pull all around, unless you dig the poke.
Old Jun 13, 2014, 02:04 PM
  #548
doncarbone's Avatar
I have the OZ Rally and i'm trying to figure out if 17x8 +25mm is going to extend beyond the fenders on 225/45/17. I need at least the +25mm offset because my brakes on the front are oversized (Wilwood bbk).
My current setup is 205/50/16 on 16x7 +43mm, and if I compare the two using this tool (http://www.rimsntires.com/specspro.jsp seems to be the best one I've found), the results indicate:
205/50/16 16x7 ET 43:
backspace: 5.7"
section width: 7.7"
tire diameter: 24.2"
225/45/17 17x8 ET 25:
backspace: 5.5" <-- should be enough still for calipers
section width: 8.9" <-- this one im a bit worried about
tire diameter: 25" <-- i think im ok?
The comparison states the fender clearance will result in the larger wheels/tires sticking out 1.3" more than what I have, which if I look at my existing setup, seems they would definitely be over the fenders by at least 0.5", although when I look at a few people's setups on here, this doesn't entirely seem to be the case...??
Not sure if anyone has ever tried 225/45/17 but would appreciate the feedback!
Old Dec 10, 2014, 08:55 PM
  #549
dannyflacoaz's Avatar
looking to put wheels on my 05 RA.. would 17x9 +20 wheels fit with stock height or would I have rubbing issues
Old Dec 16, 2014, 03:08 PM
  #550
doncarbone's Avatar
truthfully i think you will be fine, depends more on the size of tire used. a 245/40/17 is probably best, safer would be lower profile...
what may happen though, if you find you need spacers, is those are going to stick out from the fenders
Old Feb 18, 2015, 01:20 AM
  #551
MaxRalliArt's Avatar
need good look tires with flares
My all appreciation and proud of all 2005 ralliart owners.
I need your help and opinion friends.
I own 2005 ralliart and I intend to put rare fender flares for some aggressive look and wide body.
But I am not sure of the proper tire I have to use!!
My current setup as following for both front and rare:
Wheels: 17"-7/ +40
Tires: 205/45 R17
Don't know if I need to put some spacers in the rare to get the tire out of the fenders or only some wider tires will be enough to get out of the fender just a mms?
I do not want to stretch tires or camber tires, I just need to make the look of the rare setup be more wide and aggressive to fit with the flares.
Waiting your awesome replies and ideas.
Old Feb 18, 2015, 07:13 AM
  #552
Durdenss's Avatar
rear*
Originally Posted by maxralliart
my all appreciation and proud of all 2005 ralliart owners.
I own 2005 ralliart and i intend to put rare fender flares for some aggressive look and wide body.
But i am not sure of the proper tire i have to use!!
Wheels: 17"-7/ +40
tires: 205/45 r17
don't know if i need to put some spacers in the rare to get the tire out of the fenders or only some wider tires will be enough to get out of the fender just a mms?
I do not want to stretch tires or camber tires, i just need to make the look of the rare setup be more wide and aggressive to fit with the flares.
rear*
Old Feb 19, 2015, 12:47 AM
  #553
Do anybody really used this type of setup with no rubbing?
I really can't believe it.
If any had this experience, which to post some pics as I can't imagine how it will look like.
I am going to get wide and aggressive so I need to confirm this info.
Old Apr 5, 2015, 04:43 PM
  #554
Jaymetal's Avatar
225/45/17
i just put 17x7.5 +40s with 225/45/17 on my 06 RA.... and definetly lots of rub issues on larger bumps. i was surprised with not much rub from lock to lock on the front! from what i can see pulling and rolling the fenders is not going to fully cure everything because the front and back bumpers meet so high on the fenders .and being plastic they wont match the fender roll...
has anyone had sucess on pulling the thicker fender plastic?
thanks
Old Apr 6, 2015, 12:03 PM
  #555
1slowsti's Avatar
I have an 04 ralliart. I was planning on running the stock evo 8 wheels. my car is dropped on the tein s tech. I was wondering if anyone has seen a pic. I was gonna run 225/45r17 but I think it will rub now. Any help appriciated
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
