Aggressive Wheels on 2004-2006 Lancer
Old May 11, 2016, 05:56 AM
  #586
LoneLancer's Avatar
Originally Posted by bakuro117
those wheels look nice! Id say with some rolled fenders you could get off with more spacing. those appear to fit about like the stock wheels. Which means 10mm should be doable on the rears.
At the moment the 5mm spacers on the rear have the tire barely touching the arch lip, so will definatly need to roll the arches before the 10mm go on. But that is my general plan for the moment. Unless I decide to start rolling 8" wide wheels XP
I'll need to get a more up to date picture of the wheel setup as the one I uploaded was before I put the 5mm spacers on.
Old May 11, 2016, 06:39 PM
  #587
CrAnSwIcK's Avatar
oh, ok...might not be too bad then, my Cedia Ralliart enkei's sit in pretty deep, I use 10mm spacers,
Old May 13, 2016, 09:57 AM
  #588
LoneLancer's Avatar
Does anyone know what is the widest wheel setup the Lancers/RA's can run?
I have read a lot of people saying that they are running 17x8 but does anyone know if a 17x9J setup can work?
Old May 18, 2016, 12:03 AM
  #589
jcmaz's Avatar
Finally on. 16x8 +30 on 205/50/16 Hankook tires.
Side view.
Front fitment. Does not rub at all.
Rear fitment. It's bang on
Old May 18, 2016, 02:39 AM
  #590
LoneLancer's Avatar
Nice fitment, if the car was a little lower it would look really sweet
Old May 18, 2016, 05:52 AM
  #591
bakuro117's Avatar
Hell yea! I love it! Looks great man!
Old Sep 25, 2016, 03:58 AM
  #592
Pandorox's Avatar
What's up Mitsubishi owners. Jumpin' in on these forums.
Not too aggresive but she's still my baby
Running 17x7.5 +35 on 215/45/17. Hits the strut housing for some reason so got 10mm spacers on the rear as well
Old Sep 27, 2016, 12:14 PM
  #593
huttonrl's Avatar
I just recently bought Evo 8 wheels with 215/45ZR17's and am sitting on newly installed Tein S-techs. I won't be too distraught if they won't fit because the guy dipped them black to cover up the evidence of his awesome driving skills (curb rash) but they would look better than my stock wheels. If I remember right the Evo 8 wheels are 17 x 8 +38. Will these be a good fit or am I going to experience some rubbing? The measurements I think come out to being 1/2" wider than stock and .8" taller in diameter which really is just .4" closer to the wheel well. Thoughts on fitment?
Attached Thumbnails Aggressive Wheels on 2004-2006 Lancer-14449044_720191421463377_1784753289837554470_n.jpg
Old Sep 28, 2016, 06:11 AM
  #594
Pandorox's Avatar
Front should be fine. But rear you may have to run spacers.
Old Oct 22, 2016, 06:03 PM
  #595
the1ftw's Avatar
I just purchased some XXR 530's 17x7 +35 wrapped in Nitto Neo Gen 205 40r17 tires. Waiting till all the body work is done before installing them. I just want to verify that they don't require spacers. I searched and saw one person confirming it worked on his setup. But another said it hit the strut housing in the rears. Just need to know if I should order them while it's down now instead of waiting when it is finished. Also car is lowered on Tein Basic Coilovers for now. Thanks...
Old Oct 31, 2016, 06:54 PM
  #596
Resurrected RA's Avatar
I thought I would check out the new set-up while the car is still on jackstands.
I bought another set of fender flares that I'm going to extend into the side skirts this winter. I will also, use a gasket in between the body and fender flare to follow the contours.
Old Nov 1, 2016, 06:22 AM
  #597
Durdenss's Avatar
17" Rota Circuit 10's
Running 5mm spacers currently but, that may soon change.
no offense, but I am not digging those door ding protectors! unless you love 'em, SHAVE 'EM!!!
Also, a tint job would tie in those wheels nicely!
Old Nov 8, 2016, 05:44 AM
  #598
2006_RA's Avatar
Great to see the Ralliarts keeping the faith. The1ftw, those wheels are gorgeous, like the raised white lettering too. You can order the spacers, if in the end you dont need them you're out a few dollars, but that beats rubbing and then having to wait to get them when you have those fantastic rims.
Old Nov 8, 2016, 06:04 AM
  #599
the1ftw's Avatar
Thank you, what size do you recommend?
Old Nov 8, 2016, 06:32 AM
  #600
2006_RA's Avatar
I cannot say what size to get. I recommend using a site like this :
http://www.willtheyfit.com/index.php...t2=38#isPage=1
That will give you a good idea of the size spacer needed, or if any is needed at all.
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
