Aggressive Wheels on 2004-2006 Lancer
#121
ok so i checked that website and this is what i found
http://www.nlmotoring.com/ProductDet...8102N&CartID=1
question i still have is do i need hubcentric rings still??and what size should i get?? i know nothing on wheels so help me out here guys.
#122
http://www.nlmotoring.com/product-p/...slash-67.1.htm
#123
Yes, you need these...
#124
Dunlop Direzza 101's are fairly thick tires... Do you think 8-10 mm spacers will work in the back? Or is that a little to much. My tire's a 215/50/16 on a 16x8 +38 offset. But if people say 5 mm is all I need, I'll get that instead. Does anyone know a place where I can get cheap spacers?
#127
#128
I mean, a 205 will have a minor stretch on a 8" and with another 1/4 inch it's going to stretch even more. With my 215 on an 8" there's a very SLIGHT stretch but it looks nice in my opinion. A perfect size that would find on an 8" is a 225, but you'd have to roll your fenders and use huge spacers. So the best thing to do is go with a 215 tire and use 5-10 mm spacers. I guess that's what I'm going to do. I'm testing it out right now, my 215/50/16 tire on a 16x8 +38 offset can't even fit on the back without spacers. The front isn't so bad as the car is at stock height right now, but when I lower it I think I might need like a 3 mm spacer. I'm not sure if I need the spacers with the studs or the ones without it. That's what I'm trying to find out.
#129
#130
You can do that also, and roll your fenders. When I say doesn't fit, I mean, if I put on the wheel, the tire rubs on the strut thing? I don't know how to explain it, I'll take a picture sometime later on, but it covers the rear struts. My tire rubs against it and my rim would hit it.
#131
hey guys I'm looking at a set of Rota IK-R either a 17x9+35 or a 17x9.5+45 help on what will fit and what tire to get I'm am lowered on megan racing coils and am willing to camber a lot and pull and roll fenders just need some help on the measurements.
#133
ok guys got my refund so far on my list for wheels is
xxr 527's 17 x 8.25 (gold)
neo chrome open end lugs (what do you guys think?)
hub centric rings 73.1/67.1
need your input on how things will fit before i go and spend $600 thanks.
#135
