Suspension Upgrades
http://www.autopartsway.ca/partlist.cfm?mitsubishi/2005/lancer/ralliart/2.4l-l4/allb/suspension/shocks-and-struts/suspension-strut-assembly/pagenum1/tabs/positionrear
There's two from KYB on there that are universal. They have different part numbers but same description. Will either of them fit?
I ended up going with the Tein S-Tech Springs, and will be getting a rear sway bar and upper rear strut mount. Figure those will tighten up the under steer in the RA a little. Also ended up with solid motor mounts... Does anyone have the part number for the poly urethane bushing kits for our cars....
I like people like you; let me tell you real genius right here guys... The 02 to 06 OZ - Rally bushing kit fits our car. I found it on my own. White line makes the kit, in three different variations.
http://www.proimporttuners.com/parts...FdgSgQodVXAA_Q
I took your word "kit" to mean a comprehensive collection of bushings to swap out for all the OEM items like the control arms, sway bars, links, engine mounts, etc. , like is available for honda civics. These bits were mentioned in the original post.
Your definition of a bushing "kit" is the singular front lower control arm bushing. That's a "kit"?
But hey champ, insult me, it's okay, but it won't make me dumb myself down for the likes of you.
those bushings are all just for the front control arms...and a long shot from a kit...unfortunately there are no complete kits I'm aware of, I have the front control arm set, but I've yet to install them...whiteline makes two sets for our generation lancer, one set has a 12mm sleeve, and the other is 14mm...14mm is the one you want...I had to get my sleeves bored out, and I've yet to find time to install them...I did find some rear bushings at one time, but I can't remember if it was whiteline or not...
Staring to get the feeling that I will have to fab the ones that I need for the rear, I have been looking also. I wonder in the bushing for the eclipse rear would fit because a lot of the RA parts fit over there....
some parts you can buy on their own im guessing
http://www.prothanesuspensionparts.c...hi_lancer_2004
