Need to fix broken/cracked end links?
I got my 2006 lancer ralliart inspected before I bought it and one of the things that came up was cracked front end links. Are these very important. Should I get new ones asap. How hard is the install if so? Car seems to handle just fine right now.
Sway bar end links are bolted to your sway bar with only 2 nuts per side.
Very easy replacement. Possible to pry down sway bar to get links back into strut. But usually a 1 man job with proper tools. 2 man job if help is needed on prybar to collapse sway bar
should I do it ASAP
okay sounds good. I had a knocking but I thought it might have been a wheel bearing because it was only on one side. Haven't got around to jacking the car up to look at things yet. Hoping it's just my sway bar bearing because much easier and cheaper fix.
SoloSpeed101
May 12, 2015 06:48 AM
bnr34rb26dett
For Sale - Part Outs
49
Jun 16, 2014 08:45 AM
>Cataclysm<
13
Sep 25, 2011 11:09 AM
lancer02Josh
11
May 12, 2011 07:41 PM
