Stanced Lancer, Orange CA
Since nobody else has said it. GET PROPER SIZED TIRES!!!!!!!!!!!!!!!!! You have a tire that's meant to be mounted on a most likely 7.5-8.5" wide wheel. You are going to ruin the tires and the rims with that setup...just a damn sad sight.
I'm not hating I didn't say: $$&k you your car looks like ****!
I said that it looks good but Is it worth it if it is your daily driver, if you only take it out on weekends for car shows than fine, but having a mode of transportation that can not go over a speed bump or an incline and you have to spend more money on tires and the only reward is looks than you have to agree with me that it isn't very practical right? And I will say it again I respect the time you have spent to make it "look" right but I just don't see why you would sacrifice so much for so little? If I didn't make sense it is because I'm french and I typed this on my phone.
But thanks for the comments guys. Wish I had an evo like you guys but I'm fortunate enough for my parents to even buy me a car. Gotta appreciate what I have. Soon I'll have an evo and enough knowledge to get it fully function and make it a street warrior.
why get a proper size when im going form > function? I can't be this low unless my tires are stretched.
Just found this on speed hunters, apparently scrapping is part of the style:
"Hellaflush: Perfect Offset, Super Slammed and Driveable. Most owners scrape over everything and it doesn't bother them. Its a lifestyle decision that many people don't want to get out of and conform to."
http://speedhunters.com/archive/2009...efinition.aspx
I guess I will never get it, but what ever.
PS: I promise I will stop highjacking your thread
Wow, never seen the newer lancers hellaflushed out. If anything, its cool to see exterior mods in a different direction than the norm.
At least you didn't pour $$$ into a higher end looking hood, wheels, wing, side vents, and impersonator emblems to basically have a shell of something you're not (you know what im talking about). That direction of exterior mods baffles me more than the whole murders out / extreme stance / hellaflush movement.
+1. To OP, do what you want but if you don't want criticism don't post stuff like this. The blue lancer I just saw from today has 10.5s! What is going on! Im afraid to go past 8.75 due to clearance and fuction, and I have a ralliart, which should have about the same clearance as a gts or es,de etc.
