Highest Reported mileage on (08+) ralliart
Old Jan 11, 2013, 04:21 AM
  #121
danike's Avatar
2009
89,200 miles (All Highway)
July 2012 oil pan leak $300. Jan 2013 cracked manifold $1500 Owned a 1993 VR-4 before my 09 ralliart, much prefer the VR-4.
Old Jan 11, 2013, 07:14 AM
  #122
03chi-town0Z's Avatar
What's with all these manifolds cracking...?
Old Jan 14, 2013, 12:13 AM
  #123
SUX2BU85's Avatar
2009 Ralliart currently 65,000 miles.
The tranny failed at 60,215 miles due to 3rd gear going bad, got new tranny under warranty. Other than the tranny failing, the car runs great now.
Old Jan 14, 2013, 07:29 AM
  #124
RalliMark's Avatar
What exactly does third gear going bad mean? What caused the failure?
Old Jan 14, 2013, 11:42 AM
  #125
Topdown's Avatar
Originally Posted by Topdown
a little under 2050 miles, bought it May 31, 2011...
and thats being driven every day to work, after-school-care and home.
Well, its 2013 now and I have just over 6000 miles on her.
Old Jul 9, 2016, 11:36 AM
  #126
captainalvy's Avatar
I just bought my 09 Ralliart in 2014...it had 79,XXX on it so I thought it was a good deal...new to fast cars....and now its at a WHOPPING 147,XXX and im currently experiencing the car skipping all the even gears and when it gets to 5th it just stays there...It has done it in the past but I normally just turn off and restart the car and its fine...but now it does it everytime I drive...kinda sucks cause I don't even know whats wrong with it
Old Jul 24, 2016, 09:38 PM
  #127
ExArmy's Avatar
147,000km stock turbo still and SST still. Only issues had so far has been oil pump failure and pcv valve failure. I service my oil every 4,000km, and SST every 20,000km.
Old Aug 24, 2016, 02:44 PM
  #128
Rralliart09's Avatar
2009 Ralliart
118,xxx miles and no problems. Mods are in my sig and I did do the teach in for the TC-SST
Old Aug 24, 2016, 06:07 PM
  #129
Bmfromel's Avatar
Had the same problem. 2010 with 91k on it. Was doing the same stuff youre doing but one time it just would unlock and it cost me almost 10gs for a new sst. Sorry bro but i think youre also on your way there.
Old Aug 25, 2016, 11:18 AM
  #130
Jechttt's Avatar
What about the lowest 2009?
53K miles
Old Aug 25, 2016, 05:48 PM
  #131
Slee256's Avatar
53K miles
I have 2009 with 34k miles.
Old Sep 2, 2016, 08:18 AM
  #132
captg's Avatar
My 2009 Ralliart has 115,000 miles.
Old Sep 3, 2016, 12:16 AM
  #133
08Lancer89's Avatar
135k
Old Sep 14, 2016, 08:47 PM
  #134
xi
xi's Avatar
UPDATE:
I'm at 120,000 miles. This has been the most f**king reliable car I've ever had *knocks on wood* I better not jinx this by making this update.
So what have I done with it?
Every 5000 miles, 5 quarts of 5w-30 mobil 1, quake state ultimate, pennzoil platnium, or castrol edge, whichever is on sale.
Every 15000 miles, dump a large 20 ounce Techron injector cleaner into the tank, new Fram ULTRA oil filter.
Every 30k miles, new in cabin and engine air filter.
Changed the TC-SST fluid and filter at 15k miles and again at 60k miles. Haven't touched it since.
Changed coolant at 30k miles.
Changed power steering fluid at 60k miles.
Changed spark plugs at 60k miles.
Brake pads and rotors replaced at 40k miles and again at 80k miles.
ACD pump failed at 75000 miles (i think) and had it replaced.
Changed battery at 3 years and 50k miles in.
AM on the radio went out at 70k miles. Everything else works..
Everything is stock. Only have mud flaps on it.
Aside from that, I haven't serviced anything else on the car, period. Have I skipped a lot of maintenance? Probably.
My driving style? I take the car into red line at least 3-4 times every single time i drive it. On the highway, I cruise at 3500-4000 rpm for long distances (3-500 miles at a time) once or twice a month. Driving through NYC a lot. Hit enough large potholes at high speed that I've destroyed 1 driver side front tire and 2 passenger side front tires. Curbed the rear passenger tire hard enough during a misjudged corner that it threw the car into the air. Curbed the driver side and destroyed a tire. Stock rims are scuffed up and banged up but still fine. Never had an alignment, still ran dead straight up until about 2 months ago. Now very slightly to the right, very slight. I switch to winter 17" rims and tires during the winter.
The oil pan has a small rust spot. Very small leak. Heat shield on the cat rusted off, made a new one out of stainless plate. Heat shield on muffler came loose, epoxied it back on. Air conditioner still runs ice cold, never had to recharge it.
TPMS still works 50/50, surprised the batteries in the sensor are still alive after 120k miles and 7 years.
The interior rattles. I know when to shift by the sound. Upper dash = 1500 rpm, lower dash = 2000 rpm, glove box = 2500 rpm, center console = 3000 rpm, the cowling above the steering wheel =3500 rpm.
The suspension's had it. Still works but bushings are getting stiff. There's a slight clunk in the steering going over rough road. Braking hard and cornering produces a weird knocking/vibration in the steering. Going straight and braking hard, nothing. Checked all linkages in the steering and suspension and as far as I could tell everything's tight.
Started running her on 89 octane (I have money, just don't like wasting it). Haven't seen any detrimental effects even with the way I drive. Gas mileage roughly the same.
Aside from the usual small pock marks on the hood (which is aluminum, so no rust!), the headlights are still very clear, not foggy at all. Replaced the windshield at 50k miles after a harsh winter cracked it. Small scuff on the rear bumper when wife backed it into the front gate. And a bunch of small dents on roof and passenger side a-pillar from when a tree fell on it during a storm. Still on original light bulbs all around. Best car ever!
Old Oct 21, 2016, 09:40 PM
  #135
Videodrome's Avatar
09 Ralliart, I bought off a friend. He did all the regular maintenance at stealership. It has 170,000kms and that'd be just over 100,000 miles. There wasn't much major work done to car. Just regular maintenance and flushes, changing out old part but nothing major. The car runs smooth and fast. Love this beast!
Noize
Jul 19, 2023 07:20 AM
felixmjones
Jun 1, 2023 02:35 AM
evoyao
Mitsubishi TC-SST Discussion
163
May 26, 2020 12:15 AM
GSX 911
Sep 27, 2016 11:08 PM
Royal Evo
Aug 25, 2016 01:19 PM
Quick Reply: Highest Reported mileage on (08+) ralliart
