MMSC install (woofer and amp??)
Hi Guys,
I used the manual someone wrote on here to install my used MMSC unit.
(this came out of a EVO X MR)
and it all worked but I don't know where to (and HOW??) install
the Rockford Fosgate amp and woofer for the rear???
the OEM amp goes under the driver's seat, and the woofer goes in the trunk area driver's side nearest the rear of the car.... you should be able to see the mounting points if you look closely...
The wiring harness in a non Rockford car is different so the connections for the amp under the seat and woofer in the trunk aren't there. You can put them in those locations but it would take a bunch of extra wiring. Easiest way would be to go aftermarket.
KITT2012
Mar 17, 2016 02:05 PM
EKtoEvoX
Dec 9, 2014 01:04 PM
Andrew LB
Jan 30, 2012 03:12 PM
