hood latch broke
hood latch broke
So I went to pop the hood and snap, the plastic latch broke. I searched and found this https://www.evolutionm.net/forums/mi...-ralliart.html
Now I went to the stealership and they told me my car is not affected by this tsb. My car has an oct 08 build date which should be covered. They also told me they have to order a part and to come back.
I looked up the part number and its only the plastic piece that broke that they are ordering. I tried to pull the metal wire with a pair of pliers but no go even had someone push down on the hood. So I know the latch is not working. I also read there was a recall for this but can't find it now. They also want to charge me for 1.1 hours of labor when it should be .8
Who should I talk to about this or should I just bend over and let them do what they want.
That is a bulletin, not a recall, so if you are out of your basic warranty coverage limits (time or mileage) then it is no longer covered by the warranty and it IS an out of pocket expense.
If you pull on the cable with pliers (it actually takes a great deal of force to get it to work without the leverage of the handle and bracketry) and it does not open, then you probably do need a new cable, too. They may be doing both a cable and a handle, but only had the cable in stock and had to order a handle and will then perform the complete repair when all parts are available.
As far as the labor time, the 0.8 listed is the warranty allowance by Mitsubishi which is the amount that they will cover if the repair is performed under warranty.
Standardized pricing is what is used for regular customers, which is usually sourced from places like ALLDATA, MOTORS, or some other standardized source, and is probably where the 1.1 came from. You can try to negotiate them down to warranty labor rate, but that will be entirely up to the dealership whether they agree to it, or not, and they are in no way obligated to do so.
However, props to the Mitsu dealers that go extra mile in customer service!
Jameson_IXMR
21
Dec 11, 2016 07:33 PM
