Silicone vacuum hoses
Old Aug 10, 2014, 10:30 AM
mike594x's Avatar
Does anyone know of, or has come across a silicone vacuum hose set, specific to our cars? By that, I mean a set that contains all or almost all of the vacuum/fuel vapor hoses, that are also pre-sized and even possibly pre-cut into the correct lengths already. I'd like to switch out all the rubber hoses for the silicone ones. I know the silicone doesn't dry rot like the rubber ones and I believe they can hold a little more vacuum/pressure than the rubber. Just curious...
Old Aug 10, 2014, 10:47 AM
meckert's Avatar
don't know that anybody makes a set--- Hose techniques used to make sets for cars, but now only sell in bulk. Be cautious of kits and the quality of hose used, I have seen the silicone hose collapse on cheap hose kits. Hose Techniques uses good quality thick firm hose, I have used it on my Evo, and a few cars from my past with great success...again you buy in bulk from them so you need to know the size you want and its pricey, but the good stuff always is. Good luck.
Old Aug 10, 2014, 06:45 PM
mike594x's Avatar
Thanks for the input. I'll probably just have to get some bulk hosing and cut the right lengths and all. I believe most of the hoses are 6mm, but I'll have to double check that.
Old Aug 11, 2014, 07:15 AM
Veronica's Avatar
ok, but do it to pretty-up the engine bay and not to prevent rot or collapse...
The OEM hoses are good for ten years/200K miles...
Old Aug 11, 2014, 09:25 AM
mike594x's Avatar
Well, the car is only 6 years old but... I live in South Jersey. I can literally throw a rock at the ocean and the Delaware bay. Let me tell you a thing or two about salty air.............
EDIT: Actually, you should know, being in MD. And the amount of salt they throw on the roads here in the winter is just ridiculous.
Old Aug 12, 2014, 03:25 AM
DAN123AC's Avatar
http://www.lancershop.com/customer/p...productid=2257
http://www.lancershop.com/customer/p...&cat=85&page=1
Here you go
Old Aug 19, 2014, 05:38 PM
ApeIron2012's Avatar
This sounds like an awesome project. If you are really going to do this, please start a "how to" thread.
Most of us will have to do this too eventually.
Old Dec 9, 2015, 09:47 AM
Biggiesacks's Avatar
It may be possible to get that kind of life out of oem hoses, but mine started failing before 100k. There are probably many variables that determine how long your hoses will last so I don't want to discount what you are saying, but I would just add that your mileage will vary.
oops didnt realize i was necro bumping.... you ever just google search something and not bother looking at the dates?
Old Dec 11, 2015, 06:29 AM
drivejumpfly's Avatar
Right, this is an old thread. I am pretty sure Veronica meant under most circumstances the hoses last quite awhile and there is no need to waste the time and money replacing them unless you have quite a bit of miles on the car. Kind of like, if you really don't have anything else that needs more attention, then go right ahead.
letsgetthisdone
39
Dec 31, 2018 03:07 PM
bluedemon199
Jun 11, 2017 11:01 PM
Fuego
Oct 19, 2016 09:00 AM
FrenziedTom
Apr 25, 2016 07:32 PM
cts4g63
14
Dec 30, 2015 01:49 PM
Quick Reply: Silicone vacuum hoses
