14 Camry SE V-6 to 2015 Ralliart?
Old Nov 25, 2014, 08:27 PM
koolisdon2006's Avatar
Hi all was wondering what everyone would recommend to me if its a good upgrade in terms of performance? Thanks..
Old Nov 25, 2014, 09:18 PM
G20
G20's Avatar
handling, yes. Power, no.
Old Nov 26, 2014, 01:30 AM
AlDim's Avatar
The difference in handling is massive and steering feel is way better (you actually know what your car is doing vs complete lack of feel on the Camry). Stock performance in a straight line is the same as long as you are pretty close to sea level. However, the turbo drivetrain has a big advantage at higher elevation and can easily make more power if you want to mod the car.
What really matters is that the Camry is extremely soft and boring to drive and doesn't have even a hint of sportiness to it, while the Ralliart is a whole lot of fun. I recently drove a 2014 Camry for a few days and was rather glad to get out of it.
Just keep in mind that a Camry is cheap to maintain and reliable while a Ralliart has a ton of high-end goodies that will hit you in the wallet (dual-clutch transmission, AWD with diffs, turbo engine). If you want performance, I'd definitely look at the new WRX and STI as well.
Old Nov 26, 2014, 06:23 AM
Veronica's Avatar
^this.
"Hey! Nice Camry" -nobody
I do get plenty of compliments (What is it? Is it an EVO? Nice car! Cool car... etc) on a recurring basis.
Old Nov 26, 2014, 08:12 AM
xi
xi's Avatar
Maintainence is a complete nightmare compared to the Camry.
Compared the mechanical goodies. Turbo motor (hard on oil). 2 limited slip differentials, an active center differential, dual clutch transmission, hydraulic steering. All of that needs attention, something not found in the Camry.
But the drive is incredible. The amount of feel and feedback in the steering is 1000x better than the Camry. Its much easier to drive faster because you can actually feel how much grip you have left. Not to mention that you'll look like a hero in the snow with the proper tires.
If you wan something comfortable quiet reliable and fast to blast off from red lights with, get the Camry.
Old Dec 1, 2014, 07:06 AM
Veronica's Avatar
Not a 'nightmare' but it is more expensive. I do it myself easily. The only expensive part is the fluid itself.
Old Dec 2, 2014, 04:38 AM
xi
xi's Avatar
Well certain things are definitely a little more involved than a standard plug and chug.
The ACD fluid change involves a computer.
Old Dec 5, 2014, 06:37 AM
GetFoxed's Avatar
^ Don't look at the Subis - They have engine problems = No good. Pistons are weak. And its a Subi.
You should Definately by the Ralliart or Evo
I do agree with everyone else, the Camry is the easiest car to own, from a maintenance standpoint.
Old Dec 5, 2014, 04:30 PM
Thank you all for all you help. I think I'm going to buy the ralliart. )
Old Dec 20, 2014, 06:38 PM
Rralliart09's Avatar
To quote the last good Indiana Jones movie, "you chose wisely"
mitsu_lover625
May 24, 2006 06:39 PM
ewsang
May 15, 2005 09:59 AM
stygiosracing
Jan 20, 2005 03:48 AM
davidwongevo
South Region
Aug 30, 2004 08:11 PM
Quick Reply: 14 Camry SE V-6 to 2015 Ralliart?
