2010 ralliart revving weird
Hi guys and girl's , will I'm new to the Mitsubishi community I did have a Subaru WRX .the reason for this thread is because when I'm driving my car rev's up and down when it's around 2000rpm not much but you can hear it and see the needle moveing up and down but what's weird is it's not much,I hope some one can let me know what it can be for I can fix it please and thank you
i have also come from Subaru WRX chocolate pistons in the 2.5 ring land
mine also did that with throttle when i first had it but has not done it since i have done the ecu flash and the sst flash
ecu flash
sst flash
I'm sorry I didn't mention I have a 2010 ralliart and the only thing I done to the car is put a k&n drop-in filter
that's very interesting I'm gonna try it thank you for your input I will let you know if it does have it
Not only do you have to be stopped, but I believe you also have to have the gear selector in "Park" for it to switch over to S-Sport mode. Then press the "sport/normal switch" forward and hold for about 5 seconds as was stated previously.
I tryed it the same way you guy's said and I don't have it ,but I did looked at something I took the heat shield off and looked at the manifold and it looked like it was cracked in two places and welded so I looked even more and found I'm missing 3 manifold bolts so I was pissed , so now I'm gonna get them bolts and put them on I think they are 14mms
