Launch at Dragstrip
Ended up trying Launch Control today...Car took off like a bat out of hell, totally unexpected. I don't think I had the brake pressed as hard as possible given that the Trans overheat light came on. Didn't go into limp mode though.
Also don't do it too much, as it will wear out your clutches quicker.
But like Veronica said; learn to time it right and you wont get the overheat light. Plus being able to time it faster will keep the slipping down to a minimum.
Tap method gets really high. Does a jump but isn't as neck snapping experience as dumping the clutch on a manual awd car.
This is my RA with a GST Tune + Boostpill.
Tap it to 3Krpm. Then press the gas pedal fully. The RPMs go up to the 6Krpm and then the clutch engages.
I dont know if Mitsu changed the algorithm in the transmission on the RA or my old tuner was very lazy with the transmission tweaks but launching a 2015 is by far easier and more aggressive than with my old 2009.
IMO that is the best you can do with the tapping method.
If you have s-sport than use the factory launch control. Tap method does the job but nothing like launching at 5500 while avoiding the unnecessary wear and tear caused by said method. The engineers at Mitsubishi know how to launch your car just as fast as anyone else, while trying to preserve your incredibly expensive transmission. No need to worry about trying it out. If you fail launch control will save all the important bits from grenading, where as the tap method will just burn up your nice new clutch basket if done with the slightest degree of error.
Having a more than decent amount of experience with both methods I can say for a fact that the tap method heated up that sst significantly faster than factory launch method. Also my clutch wear is much better over time having switched to the launch control method exclusively. Save your money and time.
moreno78065
Jun 18, 2015 07:20 PM
akeric
17
Jul 16, 2011 09:10 AM
turbor850
Mitsubishi TC-SST Discussion
29
Dec 29, 2009 10:03 AM
R1ckyB0bbyyy
Driving Techniques
Feb 4, 2008 10:58 AM
