wheel size...
You may want to check your camber or something, because the wheel and tire specs you've given should not have any poke. I run 18x8.5 ET35 wheels with 245/40-18 tires and have 0 (zero) poke up front. The tires come to the edge of the fender but not past it, but I am also lowered and have -2* camber up front.
With the wheel and tire specs you've given, your tires should be set more in the fenders than mine.
Finally found suitable OZ Ultraleggeras...17x8 with 215 wide rubber. Runs much better compared to the stock advans, also increased comfort. Just in time for the car's 6th birthday!
