235/40 vs 225/45 Tires
I did a lot of research and finally came to the decision to get the Bridgestone Potenza RE970AS Pole Position tires in 235/40-18. The problem is that now it's hard for my local tire place to find them in that size, so they will cost more. I could get the 225/45-18 for $30 cheaper per tire, and it would be nice to fill out the wheel well a little more. The issue is that with that specific tire that I've finally decided on, the 225/45 is not an XL load range, and is only rated at a 91W, as opposed to the 95W XL of the 235/40. How much worse would this make the handling of the 225/45?
Here is a link to the tire if you want to see the specs:
http://www.tirerack.com/tires/tires....omCompare1=yes
I have 8" wide rims waiting for new tires. Are you stock height, and do you have any rubbing issues?
Suspension height is all stock. No rubbing issues.
235 wide rubber doesn't look overly aggressive on an RA (IMO), and it feels nice and sharp on the road in terms of steering feedback. Speedo accuracy is pretty good too.
It all comes down to budget. That old saying holds true... you get the best tyres the wallet can afford!
Rich
Rich
Suspension height is all stock. *No rubbing issues.
235 wide rubber doesn't look overly aggressive on an RA (IMO), and it feels nice and sharp on the road in terms of steering feedback. *Speedo accuracy is pretty good too.
It all comes down to budget. *That old saying holds true... you get the best tyres the wallet can afford!
Rich
Rich
Yeah, that's exactly why I chose the Bridgestones in the first place over the Conti DWS or Kumho Ecsta 4X. I looked at reviews and surveys, and it seemed the Contis and Kumhos excelled in certain areas but lacked in others while the Bridgestones beat out or tied with both of them in all areas. I figured tires are one area I'm willing to splurge a bit, but the new even higher quote is disheartening and making me second guess my choice.
Sweet! Thanks!
If you're upgrading anyway, I would go with at least a 235 width. Also consider running a 235/35/18. I'm running this size now and the thinner aspect ratio makes for shorter gearing. This is an often overlooked method to achieve that effect.
timereaper
Toronto Lancer Club
Mar 27, 2012 10:18 AM
LancEric
21
Dec 16, 2010 06:45 PM
limmerZ
Oct 26, 2008 04:25 AM
