Drew's 6 Pot Brembo BBK for the ralliart(TESTED AND WORKING)
I just wanted to give an update on the lines that come with the kit. Very shortly, I will be able to offer two different variations of the SS lines. One will be the standard kit, made to fit the front BBK with OEM rears, and the second will be for people who want to do the front BBK AND the Evo X rears. And for the guys that have already purchased a kit with lines, I will be offering just the secondary rear line that is required to bolt up the Evo X rears properly. Stay tuned.
I'd rather find a way to make the Ferrari California fronts fit with GTR calipers and proper pad than using these... the problem being the size is around 15.4" instead of 14" for the X rotors and the obvious large initial investment. However over the life, you will save far more money on wear of these than regular iron rings. If using something like AP or Stillen's rotors, you can get roughly 10 or more years of track use with their CCM rings which should probably bring you close to even or cheaper than iron brake options.
Thanks, Captain
A few things.....
This brake option uses the exact same pad footprint as the GTR. There would be no point in getting GTR calipers that will not bolt up to the stock spindle, when these calipers do bolt up, and are equivalent/superior to GTR calipers. All you would need to do is get carbon ceramic rotors, with the correct pad.
Also, for a rotor that large, you would have to run 19" wheels, if not 20". Most people will not want to do that.
And, most importantly, cost. You will not get remotely close to being anywhere near cost neutral over 100 years and a million miles using CCM rotors, even on a completely dedicated track car. Not close. The CCM kit that Stillen sells for the GT-R costs more than some people have paid for their RalliArt. Who in their right mind would put $18k brake pads/rotors on a car worth $20k?
But, if what you are saying is "I would rather find a way to put $24,000 brakes on a Ralliart than to spend $1400 on a kit that gives the Ralliart better brakes than the Evo X.", then I think most people would agree with you, myself included, if money was not an option.
A few things.....
CCM kit vs. rotor rings are two different things. They run a few grand each. That's not a bad deal if you do in fact decide to run the aftermarket AP rings on the GTR (or ferrari or Zr1) hats. The pads wear a hell of a lot more than the rings so virtually a few pad replacements and some resurfacing of the aftermarket rotors is all you really need. It's certainly not a 20k investment. And yes, I understand that large *** wheels are not very ideal.
I was just addressing the point of you saying you would rather find a way to do CCM instead of the kit this thread was created to review, and the two really aren't comparable in price by a huge margin. It compares, in my opinion, to going in to a thread that is reviewing a 4b11 stroker kit, and saying you would rather research doing a VR38DETT engine swap. Again, I agree with what you are saying in how awesome the CCM kits are, but lack the understanding of the concept of comparing the two. The kit mentioned here vs CCM is apples to oranges. Or more like Jack Daniels to A. H Hirsch Reserve.
