delayed shifting into reverse
Old Jan 6, 2010, 02:50 PM
Jer.'s Avatar
I've had this happen to me a few times when backing out from a parking spot...
I'll start the car, then drop the shifter into reverse, and give it some slight acceleration only to have the engine free rev as if it was in neutral. Then after about 2-3 seconds the gear will catch with a decent jerk and it will reverse. Normally as soon as i hear it freely revving i let off the gas quickly so it doesn't accelerate too quickly after it shifts.
Normal?
Old Jan 6, 2010, 03:57 PM
velocityhead's Avatar
Have you owned/driven a true manual car before? If so, you've probably experienced some similar difficulty getting the gear into reverse. It's really no different here.
The same thing has happened to me a couple times, backing out of the garage. You'll see the gear indicator (P, D, N, R, etc.) light blink on/off as it's having trouble. Shifting it to Park and then back to Reverse usually works (or just leave it idle in Reverse for a few seconds and it will kick in). When the gear indicator light comes back on steady, the SST is ready.
Old Jan 6, 2010, 04:17 PM
bmanuhutu's Avatar
SST = Stupid Slow Transmission
Old Jan 6, 2010, 04:40 PM
Jer.'s Avatar
No, never driven a m/t car, the ralliart is my first car actually.
As long as its not just me, I'm happy. Thanks
Old Jan 6, 2010, 04:51 PM
Jyrk's Avatar
learn to hold the brake until the R stops flashing on the display. Once you do that, you will not see a jerk of any kind.
Old Jan 6, 2010, 04:57 PM
Skym's Avatar
Hm... it happened to me a couple times but I've never seen the R light flashing.
Maybe I was too busy looking back to see if any cars are coming.
Old Jan 6, 2010, 05:00 PM
Jer.'s Avatar
Will do.
Maybe you can answer another question I have... I've seen a few people on this forum recommend to be in sports mode while driving in "manual" mode. It was suggested that doing so reduces clutch wear.... why?
I thought sports mode just changed the shift times when driving in auto?
Old Jan 6, 2010, 05:05 PM
XxLaNcErGTSxX's Avatar
Usually it's due to the fact thy the car is not warmed up enough. I've done some testing on my Evo and if I put it right into reverse it flashes and then finally goes. If I wait like 30sec works fine. If I haven't driven it for a few hours I let it warm up, but I do see this happening even if I go into the store
Old Jan 6, 2010, 07:07 PM
suprPHREAK's Avatar
The R on the main display doesn't flash. The R on the shifter bezel flashes.
Old Jan 6, 2010, 07:17 PM
Kieffer87's Avatar
Actually this happened to me once and the red around the R on the main display was flashing. I didn't notice the shifter bezel flashing though.
Old Jan 6, 2010, 09:02 PM
brads09lancerGT's Avatar
I actually haven't looked at the shifter bezel to see if it flashes but I do the same as Jyrk stated, I put it in reverse, hold the brake and my R on the main display will flash once after about 2 secs and then its good to go and no herky-jerky.
Victor Hong
Jul 13, 2016 08:19 AM
CaptainSquirts
May 17, 2016 08:35 PM
Rumblefish237
16
Sep 1, 2011 02:26 PM
su37su
Jul 28, 2009 01:47 PM
mitchedout
Jan 21, 2009 09:10 PM
Quick Reply: delayed shifting into reverse
