SST Decel vibration
SST Decel vibration
It has been getting worse for the last 6 months. I notice it in more in "manual" mode than "auto" mode due to the tranny downshifting itself.
When I let off the gas in 6th and 5th gear as the car slows down w/o using the brakes, I get a vibration from under the car that you can feel everywhere in the car. It is worse on 5th than 6th. It is revs dependant.
It happens mostly around 3000 and then goes away as the car slows (revs drop) and then picks back up around 2400 revs. But only noticeable when off the gas. It may be there under accelleration but harder to tell.
I can barely feel it in 4th.
Anybody else have this issue?
I wonder if I have lost a drive shaft weight?
resonance within the design of the car. add some dynamat and it'll change the rpm when it happens, but there's always gonna be a point where the rpm of the motor is the right frequency to make the car feel like its falling apart. anyone see the mythbusters episode where the 6lb weight made the san-fran bridge vibrate???
on my car, before i put the downpipe on and only had the tp/cbe, it was weird cause not only would i hit that point of resonance, but it was also the only drone point for the exhaust. i put the car throughout all different driving conditions, to see if i could get the exhaust to drone, and it would only do so at around 65-75mph on decel without braking. so at that point, it seemed like all hell was breaking loose. lol. once the dp went on, its gone. now i have done some other stuff to the car too, and it seems that on accel i get that vibration problem right around 2750rpm under light throttle, but other than that, nothing. its always gonna be there to some extent
The shaking on the first transmission was considerably worse than what the second one is producing. The vibration was actually causing a very noticable sound through-out the car and enough to rattle change/sattelite radio on the front window/reveiw mirror.
The second one produces no audiable sound but you can still feel it at certain speeds in certain gears. But no question not as bad as before.
